starting problems please help!!
Old Jun 10, 2009 | 10:05 AM
chase.vanatta's Avatar
Default starting problems please help!!
i have a 94 prelude with the jdm 2.2 vtec and im having some starting issues. it cracks but will not turn over. i changed the ignition coil like a week ago and it started fine but now its back to not starting again. so I returned the coil got a new one and a new ignition module and still no go. also just changed the fuel filter and tryed starting it with starter fluid still nothing. if anyone has any sugestions that would be great
Old Jun 10, 2009 | 10:39 AM
f22builder's Avatar
Default Re: starting problems please help!!
Did you check that is is giving spark at the plugs in the correct order ?
Is it getting fuel?
is the fuel pump fuse good?
Check and return.
Old Jun 10, 2009 | 10:52 AM
red92si's Avatar
Internal Coil?
External Coil?
Did you change the ICM and the Coil?
Old Jun 15, 2009 | 10:59 AM
it is internal coil with i changed 2 timesd and the ignition module was changes. for some reson it will start some days and not on other days, i have not checked the fuel pump fuse but the spart plugs are firing ok. I was told it could be just a wire thats shorting out every once in a while but im no machanic. thanks for the feed back
Old Jun 15, 2009 | 05:12 PM
ArmaanOG's Avatar
check your main relay
Joe19
Apr 11, 2019 05:41 PM
Leigh572981
Aug 11, 2011 02:22 PM
tgibson
10
Feb 10, 2010 04:17 AM
thunderlips
Aug 28, 2009 01:29 PM
dapaur
Nov 1, 2007 06:40 PM
