problem at low rpms
Old Jun 28, 2009 | 05:54 AM
JDM_Certified's Avatar
Default problem at low rpms
searched and can't find anything, and also been trying to figure out this problem. Well, first of all, it's a prelude with a f22a1 motor, and when u start the car it doesn't really sputter, or idile just drops, or sounds like the car is bogging, and when im driving in every gear, around 2k-4krpm(not sure exactly wich rpm) car will sputter or has a bogging sound, then it goes away, after..can't figure out why. checked plugs and wires, and they're still good, but one more thing, the person i bought the car from mod he's ignition coil, he took out the one inside the dizzy, and use a msd blaster coil 2, and i can't find the 2 wires that goes inside the dizzy for the interanal coil even the one connects to the harness, but he ghetto riged it into one of the harness..could that also be the main cause?
Old Jun 28, 2009 | 07:11 AM
lude72's Avatar
Default Re: problem at low rpms
it sounds like fule problem if it was the coil it wouldn't run at all . check your fule filter
Old Jun 28, 2009 | 01:12 PM
slow96lude's Avatar
try replacin the fuel filter and see if that doesnt help it out. may be the pump going out
Old Jun 29, 2009 | 01:41 AM
that's what im thinking, it has a fuel feeding problem..argghhh...im going to check my fuel filter
Old Jun 29, 2009 | 01:42 AM
what makes u say it's the pump
*EGK*
Sep 11, 2010 07:32 PM
JDM_Certified
Jun 29, 2009 12:29 PM
Ed 341
Dec 26, 2008 11:58 AM
Lokisdope
Dec 25, 2007 05:49 PM
ckamaras
Mar 18, 2006 03:18 PM
