Wont start
Old Jun 15, 2009 | 05:29 PM
tmrtwo's Avatar
Default Wont start
I removed my vafc from my car.After i connected my wires back together for the ecu harness and plugged the ecu in....the car wont start. The fuel pump isnt priming and the car isnt getting spark. Any idea?
Old Jun 15, 2009 | 07:13 PM
slow96lude's Avatar
Default Re: Wont start
main relay possible, check your fuses
Old Jun 16, 2009 | 08:35 AM
tmrtwo's Avatar
I checked all my fuses....gonna have to check the main relay....there a way to test this?
Old Jun 16, 2009 | 09:51 AM
ArmaanOG's Avatar
just listen for the clicks in your dash when u first turn the key with all dash lights on.
Old Jun 16, 2009 | 04:59 PM
slow96lude's Avatar
yea. or just take it out from under your dash and remove the plastic cover and inspect the solder on the the top of the board. they will be cracked if it is bad. kinda hard to see unless you get a really good close up
Old Jun 19, 2009 | 02:51 PM
tmrtwo's Avatar
hmmmm yea main relay looks good and i hear 2 clicks......Any other ideas?I had radio playing while changing the ecu....would that blow anything?
Freemananana
Sep 11, 2014 12:13 AM
Rickdogg
Feb 18, 2012 12:26 AM
SiRkid
Aug 5, 2009 04:42 PM
si90rex
Acura TL, RL & ZDX
Jun 16, 2006 05:22 AM
ludicrous
Jun 17, 2004 08:20 PM
