heat wrap?
Old Jun 16, 2009 | 11:44 PM
fraserboostedh22's Avatar
Default heat wrap?
hey all. just wondering does heat wrapping the manifold and the down pipe helps much with the engine cooling? TIA.
Old Jun 17, 2009 | 01:22 PM
MikeLuder's Avatar
Default Re: heat wrap?
yeah it works, but I can tell you from experience that it will eventually crack your manifold. It could potentially be three years later, but it will do it.
Old Jun 17, 2009 | 01:29 PM
NirVTEC's Avatar
3yrs/30k miles with heatwrapped Vibrant header and no issues......
Keep underhood temps down for sure......
Old Jun 17, 2009 | 02:09 PM
dahmuno's Avatar
i have a 4 ft insulation on my turbo and downpipe, and heatwrap on the turbo manifold. wouldnt even think of going without this stuff especially with a turbo and all that heat soak. it reduced my under hood temps massively.
Old Jun 17, 2009 | 02:17 PM
fastracer2001's Avatar
going onto my 2nd year with my camp1320 header wrapped and no problems.
Old Jun 17, 2009 | 02:44 PM
NirVTEC's Avatar
everything is bound to break on that thing anyway!
Old Jun 17, 2009 | 07:40 PM
MikeLuder's Avatar
yeah, i'd say go ahead and do it. it's probably worth it, and when my header cracked I just had it re welded so
Old Jun 17, 2009 | 08:58 PM
jlude90's Avatar
also keeps heat in the exhaust making the gases flow better, making the exhaust evacuation more efficient
Old Jun 22, 2009 | 11:54 PM
thks everyone for the advices. i will order some wraps tomorrow. thks again
Old Jun 23, 2009 | 10:25 AM
Edul59's Avatar
is it good to wrap the whole top and down pipe? i mean why not right...i was thinking about just wrapping the manifold..
Old Jun 23, 2009 | 11:13 AM
Edul59's Avatar
another Q: do you have you use hose clamps?
Old Jun 25, 2009 | 01:53 PM
ceezo70's Avatar
they have heat ties...check this site out
www.heatshieldproducts.com
Old Jun 25, 2009 | 04:10 PM
Edul59's Avatar
thanks for the nice site
Old Jun 25, 2009 | 06:46 PM
E-Money's Avatar
why not just get it jet hot coated. heatwraps have a potential to trap moisture in the wrapping if not wrapped correctly. eventually blowing out your piping. On a basic bolt on setup, from my experience, a aftermarket exhaust manifold does not get that hot compared to the stock setup with the heatshield. if your serious about blowing money on your honda get it jet hot coated. http://www.jet-hot.com/headercoatings.html
Old Jun 25, 2009 | 07:47 PM
Lude Acts's Avatar
Yeah, heat wrap is controversial.....Everybody who doesn't have it, thinks that it will crack your header. Everybody I've ever met or talked to who ACTUALLY has a wrapped header, has never had a problem. If you wrap it correctly, and don't have any gaps or too much overlap, you should be good.
Plus, it just looks baaaaaaaaadddddddddddddddaaaaaaaaassssssssssssssss ssss.
But I advise only doing the upper section of a 4-2-1 header, as going too far down with the wrap, may actually be able to hold moisture. Just to be on the safe side, I'd only wrap piping that is inside the engine bay, not anything underneath the car.
Old Jun 26, 2009 | 03:27 AM
E-Money's Avatar
is that coated and wrapped oem?
Old Jun 26, 2009 | 06:50 AM
blaze.1's Avatar
I've been thinking about wrapping my header for sometime now. I have to agree with lude_acts, it does look good. If I order a one inch wide roll, 50 foot long, will that be enough to wrap the entire header as it should be?
Old Jun 26, 2009 | 08:45 AM
Lude Acts's Avatar
Mine is painted with high-temp header paint, only the first 2 inches. I didn't paint the hole thing because I wasn't sure how the paint would hold up under the wrap. The paint has to be able to do its thing, and with the wrap holding that heat in.....I just wasn't sure. Yes, it is OEM manifold, so I'm not even worried if it cracks. I could always just get another on ebay for $20. My friend has had his DC header wrapped for over 3 years with no problems. I used 2" wide x 50' long roll and had leftover, but I only did the manifold, not the downpipe. I suggest ordering extra stainless zip ties, if you go that route, as I messed up a few of them and was glad I had extra. Or you can use SS hose clamps or just plain SS wire.
Old Jun 26, 2009 | 01:48 PM
Edul59's Avatar
that wrapping looks legit..very nice
Old Jun 26, 2009 | 08:03 PM
Lude Acts's Avatar
Thanks. I know a lot of people hate on wrapping the header, but regardless of what anybody says, it looks way better than a lame *** heat shield with the "don't touch" logo, or a stock rusty header without the heatshield. If you are looking for a major performance gain, heat wrap isn't going to give it to you, but I just love the way it looks.
Yellowone
Jun 10, 2006 02:30 PM
crxnj
11
Apr 24, 2006 01:58 PM
boostedblack99
Feb 17, 2005 10:56 PM
BoostedVtecGsr
Aug 25, 2004 06:11 PM
01ITR#700
Jan 11, 2003 04:38 AM
