Question about OBD1
Old Jul 19, 2010 | 08:40 AM
98BBSiCxs's Avatar
Default Question about OBD1
ive read a couple threads and there is a lot of confusion about the JDM H22a swap into a 5gen. I still don't know what is all needed to do the OBD2 to OBD1 conversion.
i know you need an OBD1 ECU, OBD2a to OBD1 jumper harness, the Peak & Hold injecters, and obd1 resistor pack. Is there anything else needed to run OBD1?
Also, which would be the better option w/o burning a whole into my pocket?
A) should I replace all the parts and stay obd2. Swaping the oil pump with 2sensors, im etc.
B) Convert to obd1
Old Jul 19, 2010 | 03:26 PM
thegr8cs's Avatar
Default Re: Question about OBD1
Stick with OBD1. I had my motor built by King Motorsports and they took my 5th gen from 2 to 1 using Hondata. I forget the model number of it, but you can only pick them up used. This will be easier than converting to 2 anyway.
Old Jul 20, 2010 | 12:53 PM
jkoni426's Avatar
if you need to pass emmissions in your area, have to stay obd2
crxb16a90
Engine Management and Tuning
Mar 2, 2010 04:42 PM
sevenfc
Apr 22, 2009 08:02 PM
boostin92hatch
Sep 27, 2007 11:59 AM
FastAzzCivic
Aug 6, 2006 08:21 AM
