M2F4 and lsd
Old Aug 7, 2010 | 03:09 PM
mach3lude's Avatar
Default M2F4 and lsd
My tranny just took a crap and i got a m2f4, i know it doesnt have lsd and i read somewhere that the jdm lsd doesnt work in the usdm trannys. So will a kaaz or quaife lsd work in the M2F4 or cant you put lsd in the M2F4?
Old Aug 7, 2010 | 04:40 PM
92civlude's Avatar
Default Re: M2F4 and lsd
The M2B4 LSD will not fit. Not sure about the T2W4 LSD. But there is plenty of aftermarket support for the M2F4 LSD application.
Old Aug 7, 2010 | 04:57 PM
mach3lude's Avatar
ok thanks, i heard the m2b4 lsd wouldnt fit and was worried that the aftermarket ones wouldnt fit either.
Old Aug 7, 2010 | 05:13 PM
92civlude's Avatar
Nah... The M2B4 is the oddball tranny. Its the red headed step child of H transmissions. Youre good.
Old Aug 7, 2010 | 05:17 PM
Apex1972's Avatar
you can use the M2B4 part of the transmission housing that holds the differential and cut the webbing from the other side of the housing so your JDM LSD will fit.
Old Aug 7, 2010 | 05:23 PM
92civlude's Avatar
Ive read the M2B4 diffs are weak. Any input?
Old Aug 8, 2010 | 09:35 AM
jnv255's Avatar
quaife
Old Aug 8, 2010 | 04:19 PM
megomaniac's Avatar
mfactory in mine,
Old Aug 9, 2010 | 02:54 PM
Apex1972's Avatar
I have one in mine and I have had no problems with it. It is actually easier to break a Quaife than one of these. The JDM LSD do not use gears or clutches, so no gears to break and no clutch packs to wear out. It is called an uncontained viscous diffferential. Read up on it.
Old Sep 19, 2010 | 06:10 PM
mach3lude's Avatar
where are ppl ordering their quaife lsd's for 800 bucks? every i looked they're all 900-1000
Old Sep 19, 2010 | 06:17 PM
vinuneuro's Avatar
This store through google shopping has it for less than 750 shipped. It's the lowest price I've ever seen.
http://www.tunersports.com/product/q...df5u_1573.html
Viscous lsd's are next to useless compared to helical and clutch-type.
Old Sep 19, 2010 | 08:58 PM
Apex1972's Avatar
please explain. i had one from a JDM tranny installed and it is alot better than the open diff that I used to have. I mean would Honda put a useless LSD in one of their cars,really. All I know is i can roast both tires really good at the track where before it was all one tire on fire.
Old Sep 19, 2010 | 09:58 PM
vinuneuro's Avatar
Viscous is def better than an open-diff, but it's severely lacking compared to the other two. Viscous usually has much lower bias, and it's not very responsive at all. There's a reason ITR, Euro R, S2k's etc got torsen diff's. It's also no coincidence that a lot of Z (and other models that came with viscous stock) owners swap out the stock viscous diff.
It's always better to get a non-M2B4 trans and add an aftermarket diff.
Old Sep 20, 2010 | 09:46 AM
Apex1972's Avatar
right. I just had some spare stuff laying around and had a very low mile M2S4 tranny and wanted to try it out. Would a diff like this benefit from a additive such as this?
http://www.crcindustries.com/auto/co...?PN=402508&S=N
currently using Penzoil synchromesh and I am happy with it.
da6xsi06
Transmission & Drivetrain
Oct 6, 2010 04:47 AM
please_hop_off
Dec 20, 2009 04:11 AM
HondaPH22
Nov 23, 2006 12:52 AM
crj_lll
Dec 16, 2003 01:24 PM
citrusdrop
Oct 23, 2003 10:59 AM
