need help testing the TPS and ect circut.
Old Jul 18, 2010 | 09:29 PM
njkill's Avatar
Default need help testing the TPS and ect circut.
the ecu is a poa odb1
engine f22b1
harrness is a 90prelude odb1 Rywire modded swapharnes
d11 is tps signal return right?
and d21 an 22 are sg - ...and 19 20 are vcc + leads right?
dose it matter witch.? or should it be one or the other?
and d13 is the ect right. dose that use one of those 2 wires to ...the sg leads?. to ground.? dose it matter whare you ground it?
can i bypass the harnnes with a wire, ecu to senser, to see if the harness is grounding and cousing the engines bad behavure while the ect is conected.?
thanks any help is great
Old Jul 18, 2010 | 09:31 PM
b18cKoupe's Avatar
Default Re: need help testing the TPS and ect circut.
What chassis?
Old Jul 19, 2010 | 04:55 AM
njkill's Avatar
90prelude
Old Jul 19, 2010 | 07:28 AM
njkill's Avatar
nothing? is this not somthing use guys know about?
Old Jul 20, 2010 | 01:43 AM
holmesnmanny's Avatar
You're in the wrong subforum. Try the prelude subforum.
toolbox21
May 28, 2008 04:02 PM
sk8shorty012
Apr 19, 2006 11:00 PM
BoostedB20A
Jan 30, 2003 03:24 PM
