wheel selection...
Old Apr 17, 2003 | 06:39 PM
sslude's Avatar
Default wheel selection...
okay, i need a lightweight (under 13 pounds) 16" gunmetal, steel gray, or silver wheel. i also need it to look nice with a base pearl white 5th gen lude with no kit (base skirts and rear not painted). i would also like to know how much they would help in the quarter mile. i would prefer them to be under 600 a set. could you also recommend a tire, size (__/__/16), and how much all of this costs. thanks
Old Apr 17, 2003 | 07:20 PM
93ludeSi's Avatar
rota slipstreams, 16' at 13.5 lbs, check ebay, you can get them for around 400 a set
Old Apr 17, 2003 | 07:28 PM
sslude's Avatar
Default Re: (93ludeSi)
i dont like the look of those...
Old Apr 17, 2003 | 07:43 PM
optikal_blitz's Avatar
rota grids! i think they are just around 13 lbs.
Old Apr 17, 2003 | 08:07 PM
1-Bar's Avatar
Default Re: (NatakuBlitz)
The rota grids in a 16" run about 16lbs roughly.....Someone in the classifieds are selling some and listed that as the weight.
Old Apr 17, 2003 | 09:21 PM
my bad- i probably misread somewhere
Old Apr 17, 2003 | 09:41 PM
DsITR's Avatar
16" Rota Grids are 14.5lbs.
mine are on the way...I will verify the weight when I get em.
as far as rec'd tire size
I go w/ 215/45/16 Azenis..
Old Apr 17, 2003 | 09:53 PM
sslude's Avatar
Default Re: (dsludefosho)
well i dunno about the tire size but i want the tire to be wide, well wide enough so its not stickking out yet its about a finger width inward. does that make sense? i dont want the tire to stick out, but i dont want it to be inside like stock.TIA
Old Apr 18, 2003 | 02:46 PM
sslude's Avatar
Default Re: (sslude)
okay now i decided i want 17's. i want the rota subzero's. how much would that low my car down? and what tire size should i run? thanks
also, can you guys refer me to a nice tire (good/okay grip) and extra light. gracias
Old Apr 18, 2003 | 02:57 PM
Regal's Avatar
Ladies and gentlemen we are floating in space...
They won't slow your car down much, if at all. The lude already has 16s to begin with, and they are probably not even significantly lighter than 17 inch Rotas.
Old Apr 18, 2003 | 03:04 PM
TurboLude97's Avatar
Default Re: (Regal)
the stock wheels on the base 5th gen ludes weigh 19 lbs and the 17" rotas weigh 16 i think.
Old Apr 18, 2003 | 03:21 PM
sslude's Avatar
Default Re: (TurboLude97)
i htought they were 21 pounds for the base wheels. and the rotas are 16.5 i believe. so what size tire should i get? i am dropped 1/5 inches all around. i have a 2 1/2 finger gap in front. and a 2 finer gap in back. is there a way i can get my car to look lower wtih the tire size? thanks. BTW, how wide should i go? again, not so it sticks out, but just barely inside, and i mean JUST BARELY inside. TIA
Old Apr 18, 2003 | 08:18 PM
sslude's Avatar
anyone?
Old Apr 18, 2003 | 08:24 PM
Boostless97Lude
Guest
Posts: n/a
i considered puting on a monster set of 225/45 R16 on my Grids when they come in, talk about wide as ****, but i can't afford a hundred bux a tire for some wheels that will be mostly used for auto-x and dicking around (burnouts etc), i will save the money and go towards those 18s i want and roll some nice Z rated 150+mph tires on them, but for my 16s, some cheap *** Falken Azenis are good enough for me
Old Apr 18, 2003 | 08:31 PM
sslude's Avatar
Default Re: (Boosted97Lude)
how much is one inch in mm's?
Shoob
Mar 11, 2007 06:35 PM
1995Civiccx
Feb 9, 2007 11:50 AM
lv6l
Dec 22, 2004 05:58 PM
boosted lude
Jun 24, 2004 07:16 PM
