engine code question
Old Apr 19, 2003 | 01:52 PM
RabbittZ's Avatar
Default engine code question
whats the difference between the normal prelude, the Si, and the SH??? what are the engine codes and what is different about them all?
Old Apr 19, 2003 | 05:45 PM
DirtyLude's Avatar
Default Re: engine code question (RabbittZ)
There's no difference that I can think of. The older the car, and the lower the OBD number, the more limited the engine codes are, but they are all the same. As they OBD gets more complex they just add more codes. The SH doesn't have any special engine codes, but it has a seperate ATTS error indicator light.
For a list of codes:
http://www.hondaprelude.to/main_checkengine.html
Old Apr 19, 2003 | 06:14 PM
RabbittZ's Avatar
Default Re: engine code question (DirtyLude)
hmm maybe i asked it wrong... they cant all be H22A motors... thats the code i meant. and why do the SH motors put out more power than the normal prelude?
Old Apr 20, 2003 | 05:10 AM
DirtyLude's Avatar
Sorry, I'm going on about error codes, when you just want the engine codes, right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">H22A1- USDM 2.2L DOHC VTEC- 92-96 Prelude VTEC (190hp)
H22A4- 2.2L DOHC VTEC- 97-01 Prelude VTEC/SH (97-98: 195hp / 99-01: 200hp)
H22A- JDM 2.2L DOHC VTEC- 92+ Prelude Type-S, 97+ Prelude SiR S Spec. (220ps)
H23A1- USDM 2.2L DOHC non-VTEC- Prelude Si (160hp)
F22A1- USDM 2.2L non-VTEC- 92-96 Prelude S/90-93 Accord LX/EX (130hp-135hp)
Those are just 4th/5th Gen codes. There's also some odd European engine codes.
SH motors don't put out more power than the normal prelude.
Old Apr 20, 2003 | 05:35 AM
rjr162's Avatar
actually i think the SH's do, a very small amount more, due to the slightly more agressive cams (its like what... 0.1 more?) I forget now. Honda did this to make up for the extra weight of the ATTS system
Old Apr 20, 2003 | 12:46 PM
RabbittZ's Avatar
Default Re: engine code question (rjr162)
are all these engines about that same size? i want to go the H22 swap into my hatch and want the most power for my money , but yeah, the SH motor sounds like that best to fit me. wanna stay US motor. but anyone have any suggestions?&gt;
Old Apr 20, 2003 | 05:54 PM
RabbittZ's Avatar
Default Re: engine code question (jz)
do you mean, what am i planning on doing with it?
Old Apr 20, 2003 | 06:31 PM
DirtyLude's Avatar
There is nothing in writing or in dyno plots that says the SH motor is more powerful. The Helms manual lists more aggressive cam, but the SH and the base model have the same cam part number. Also to the wheels the SH loses more power do to the added powertrain loss of the ATTS.
RabbittZ, if you're thinking of swapping an SH motor, I'll tell you right now, you don't want it. The SH motor comes with the ATTS unit. If you want the ATTS to be more than just a paper weight, you need to implement all the sensors that the ATTS computer relies on throughout the car. There's a vertical G sensor, yaw rate sensor, individual wheel speed sensor and more. They have to be placed perfectly in the car, and even then if the car has a shorter wheelbase, or if the ATTS computer sees anything it feels is out of it's parameters it will shut the ATTS off. It's very finicky. The ATTS unit even needs it's own oil cooler.
Old Apr 20, 2003 | 06:42 PM
satan_srv's Avatar
Agreed. I would say get a JDM H22a 4th gen motor...but you say you want USDM....get a 4th gen motor if you can, but mileage will be higher...
Old Apr 20, 2003 | 07:45 PM
RabbittZ's Avatar
Default Re: engine code question (satan_srv)
what is the ATTS that you speak of?&gt; i dont know what it is? but thanks for the info.. and why the 4th gen motor? why not a 5th? just asking.. so please fill me in. and just as a reminder.. this is ging into a 95 hatchback. so all help, ill be more than greatful to hear!. thanks everyone.. and keep the help coming. :D
Old Apr 20, 2003 | 07:46 PM
RabbittZ's Avatar
and as it was said above... the SI in non-vtec??
crystalblue99lude
Sep 10, 2005 11:31 PM
CivicVX94
Dec 1, 2004 10:08 AM
benny27
Feb 3, 2004 11:35 AM
