will SH shocks/struts work on a Base model???
Old Apr 19, 2003 | 11:08 AM
Boostless97Lude
Guest
Posts: n/a
Default will SH shocks/struts work on a Base model???
i found some Koni shocks on eBay for an SH model. i was just wondering if they would work on a base model?? TIA
Old Apr 19, 2003 | 11:59 AM
kotetu's Avatar
Default Re: will SH shocks/struts work on a Base model??? (Boosted97Lude)
ahahah I emailed the seller on that! lol he said he wasn't sure, but that Base shocks supposedly don't work on the SH.
Old Apr 19, 2003 | 02:48 PM
sslude's Avatar
Default Re: will SH shocks/struts work on a Base model??? (kotetu)
i dont think it does.
Old Apr 20, 2003 | 12:07 AM
BB6-00's Avatar
It should work as long as the chassy is the same....
Old Apr 20, 2003 | 07:51 AM
One Slow Lude's Avatar
depends......
the suspension is different, but.....
i have an sh and i called koni because they didnt have a apllication for sh shocks (which makes me wonder what the hell the guy that has them is talking about) but they said that if you get base model shocks and springs then it will work, but one will not work with the other (ex. sh shocks with base lowering spring....) so i am pretty sure that you can use them in your base lude......i havent called koni in a while so maybe they did get shocks for sh's out...
he is certain they are for an sh?? because when i was lookin they didnt have one for the sh, so i got the base shocks and then H&R springs for the base and it works fine
Old Apr 20, 2003 | 08:20 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: will SH shocks/struts work on a Base model??? (POSlude97)
it will work but you'll need adapter rings so the spring will sit right. thats what koni told me. i was gonna go with koni/vis coilovers but i went for tein instead. i still have adapter rings unused if anyone needs em for koni shocks.
Old Apr 20, 2003 | 08:24 AM
Default Re: will SH shocks/struts work on a Base model??? (Sticky Tires)
so your saying koni makes an SH shock now????
those bastards.......
Inextricabledrvr
Mar 8, 2005 07:22 AM
Inextricabledrvr
Apr 27, 2004 10:32 PM
SupRlude01
Nov 10, 2003 05:55 AM
DCbb6
Oct 1, 2003 10:36 AM
jeffe
Mar 7, 2003 11:47 PM
