MSD Distributor Cap??
Old Oct 3, 2003 | 11:10 AM
h22aLSD
Guest
Posts: n/a
Default MSD Distributor Cap??
Does MSD make a distrbutor cap with the coil plug so u can just plug your external coil into it??? I m asking cause i just my h22a LSD into my '00 Accord and wanna put the msd that i had into it. Thanks for the info.
Old Oct 8, 2003 | 07:06 AM
h22aLSD
Guest
Posts: n/a
Default Re: MSD Distributor Cap?? (h22aLSD)
to the top...
Old Oct 8, 2003 | 12:35 PM
Doc_Honda's Avatar
I dont know about you... but my H22A4 already came with an external coil. Cant you just plug into the stock distributer cap?
MSD is really just a waste of money unless you run N02 or another form of FI
Old Oct 10, 2003 | 07:18 AM
h22aLSD
Guest
Posts: n/a
Default Re: MSD Distributor Cap?? (Doc_Honda)
I agree about the msd being uselss unless ur using FI but thats why i am going to put it on because i had boost on my accord motor and am going boost on my h22a so thats why i wanna install it.
Old Oct 10, 2003 | 07:48 AM
skrewdlude's Avatar
hey man,
MSD doesn't make one for our cars, and the coil wire has to be modded to fit or external coil plug in on our stock cap. What I did was got a 1990 Accord Dizzy cap (same as the JDM H22 distributor) then I got the MSD power tower conversion piece, along with the MSD Helicore wire. It works great. This only pertains if you are running the SS coil I believe because the other blaster coils will fit on the stock coil wire I think...
There it is on my old car, the car is turbo just not in that picture... The only reason I got it was cause my stock coil died and I thought I would upgrade, but looking back it made very little difference.
Josh
newfie24
Apr 14, 2006 07:36 PM
SpoolnByYou
Mar 25, 2006 09:10 AM
dvp95
Jun 19, 2002 07:01 PM
gringo7718
Feb 14, 2002 03:42 PM
crx(gator)
Dec 4, 2001 09:09 AM
