vtec controller setting
Old Dec 21, 2003 | 09:54 AM
Nospace's Avatar
Default vtec controller setting
since the vtec is set so high on the prelude(5th gen), where should one set the vtec controller at....might be a nube question..so plz answer thoroughly, ty... h-t
Old Dec 21, 2003 | 10:57 AM
thehondaguru's Avatar
Default Re: vtec controller setting (Nospace)
Most people have good luck @ 4700 to 5000 rpm. I liked mine @ 48000
Old Dec 21, 2003 | 12:19 PM
Behan's Avatar
Default Re: vtec controller setting (95 lude)
it should be set on a dyno, specifically when the lower cam lobe power peaks.
Old Dec 21, 2003 | 03:05 PM
LudeyKrus's Avatar
Set it up on a dyno....but other people have said that dropping it a bit has flattened out the torque curve a bit.
Old Dec 22, 2003 | 12:39 AM
@ries's Avatar
Default Re: vtec controller setting (93preludevtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludevtec &raquo;</TD></TR><TR><TD CLASS="quote">it should be set on a dyno, specifically when the lower cam lobe power peaks. </TD></TR></TABLE>
which vtec controller are you using?
Old Dec 22, 2003 | 01:16 AM
preluda92's Avatar
Default Re: vtec controller setting (emoBB1)
go to a dyno, run it with no VTEC crossover, then with VTEC on the whole way. Wherever the two torque curves cross there is your optimum point.
Old Dec 22, 2003 | 07:32 AM
LudeyKrus's Avatar
Default Re: vtec controller setting (preluda92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preluda92 &raquo;</TD></TR><TR><TD CLASS="quote">go to a dyno, run it with no VTEC crossover, then with VTEC on the whole way. Wherever the two torque curves cross there is your optimum point.</TD></TR></TABLE>
smart man
Old Dec 29, 2003 | 01:14 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 lude &raquo;</TD></TR><TR><TD CLASS="quote">I liked mine @ 48000</TD></TR></TABLE>
Good god.. What type of valve springs do you have to rev past 48000 rpm's..
rocket256
Feb 12, 2005 03:09 AM
RJH6
Apr 12, 2004 03:37 PM
gutted
30
Jan 27, 2004 08:17 AM
af97civic
Jun 18, 2003 08:04 AM
1 2 NV
Apr 12, 2003 10:01 PM
