internal coil to external coil conversion
Old Dec 22, 2003 | 08:27 AM
dominate9's Avatar
Default internal coil to external coil conversion
I have a JDM motor so my distributor has an internal coil. I want to put an ignition system on it with an external coil. I haven't found any modified caps for Preludes...go figure. I heard that there is a way to convert my internal coil to external. Sometimes about just drilling a hoole into my cap and attaching another terminal. Anyone done an internal to external conversion? Anyone have any info?
Old Dec 22, 2003 | 08:29 AM
BoostedH23a1's Avatar
Default Re: internal coil to external coil conversion (dominate9)
just like D16s
drill a hole on the bottom of the cap, soder the wires to make them longer then run them to the external coil, seal the cap, presto
Old Dec 22, 2003 | 09:46 AM
machine4321's Avatar
would you need a usdm lude cap though ?
Old Dec 22, 2003 | 10:19 AM
117's Avatar
117
I'm not sure if you have to be a member of PO.com in order to view this thread, but here's a write up of how to convert the JDM H22 distributor to use an external coil.
http://www.preludeonline.com/s...butor
Note that this is for use with the USDM engine harness. This will not work with the JDM engine harness.
You use a USDM H22 distributor cap and rotor after the conversion. I did this on a JDM H22 install I did on a 1992 Prelude S model. It worked perfectly.
Old Dec 22, 2003 | 08:49 PM
dominate9's Avatar
I can't get to the PO link. Does anyone have any other links ?
Old Dec 22, 2003 | 08:51 PM
dominate9's Avatar
Default Re: internal coil to external coil conversion (BoostedH23a1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedH23a1 &raquo;</TD></TR><TR><TD CLASS="quote">just like D16s
drill a hole on the bottom of the cap, soder the wires to make them longer then run them to the external coil, seal the cap, presto</TD></TR></TABLE>
Yeah, I heard about the drilling the hole part. But it calledfor adding a terminal instead of extending the wires. Got a link?
plugger
Feb 23, 2012 07:17 PM
crxY-49
Oct 21, 2003 06:43 AM
dominate9
Aug 24, 2003 03:37 PM
insane900rr
May 25, 2003 04:44 AM
