Valve float?
Old Dec 15, 2003 | 07:25 PM
92LudeSI's Avatar
Default Valve float?
Im getting a set of webcams for my h23. I dont plan on doing any other modifications to the head at the time and someone was saying that I needed to worry about valve float? I searched but couldnt find anything, do I need to worry about this with stage 1 cams?
Old Dec 15, 2003 | 07:33 PM
Mike95lude's Avatar
Default Re: Valve float? (92LudeSI)
If I were you I'd ask Webcams what they think. I personally don't know how much more aggressive a cam the stock h23 valvetrain can reliably handle.
Old Dec 16, 2003 | 05:31 AM
Revi's Avatar
Just upgrade to heavier lb springs. Whats the lift on the cams?
Old Dec 16, 2003 | 06:11 AM
92LudeSI's Avatar
The lift is .390
Old Dec 16, 2003 | 06:17 AM
SKDRCR's Avatar
Default Re: (92LudeSI)
I thought webcams didn't offer anything for the h23 valvetrain
Old Dec 16, 2003 | 06:31 AM
Revi's Avatar
whats the max lift the stock H23 springs can handle? Valve float happens when the valves are opening and closing at high rates. If the valve springs dont produce enough pressure to be able to close the valve in time before it reopens, it will float. This is normally at high RPM ranges 8K+. As long as you dont plan on reving to sky high RPMs you should be fine, but check your current springs to see whats the maximum lift.
Stage I cams are usually mild, and stock head components can be used.
Old Dec 16, 2003 | 06:38 AM
v4lu3s's Avatar
RTFM
ask web cams
the lift is important as well as the rpm of the engine...and the steepness of the ramp on teh lobese....the makers of the cams would eb the best to listen to for requirerments with their cams....
Old Dec 16, 2003 | 06:51 AM
SKDRCR's Avatar
[QUOTE=92LudeSI]Im getting a set of webcams for my h23. [QUOTE]
so you are going all motor h23
Old Dec 16, 2003 | 12:40 PM
92LudeSI's Avatar
I plan on going all motor yes hopefully with an h22 but right now i can pick up a set of these cams cheap and i just want a bit more top end with the h23.
Old Dec 16, 2003 | 12:42 PM
92LudeSI's Avatar
I talked to webcam and they said i should have any problems as long as i dont try reving high which im not anyways so thanks for your help
Old Dec 16, 2003 | 03:47 PM
rocketlude's Avatar
A set of retainers would give you an extra saftey margin and are cheaper than springs.
just_stock
May 3, 2024 02:23 PM
SubwayH23
Jul 15, 2018 08:27 AM
Pullig
Feb 1, 2006 11:47 PM
BoostedH23Accord
Sep 22, 2004 08:30 AM
str8rcn
Mar 24, 2002 09:53 AM
