shock and spring install
Old Dec 24, 2003 | 10:23 PM
noble4ws's Avatar
Default shock and spring install
sup guys, i have a 92 prelude 4ws and i just got eibach sportlines and kyb agx's i was wondering if there is anything i should know before going into this, if there is an installation write-up anywhere and how much i should cut the bumpstops, any info would be great i did a search and didnt find any real answers, especially for the bumpstops thanks.
Old Dec 24, 2003 | 10:35 PM
makavelli1227's Avatar
airtools are your friends.
Old Dec 24, 2003 | 10:52 PM
speedracer9k's Avatar
for the bumpstops....cut off 1/2 and use the bottom half of them
Old Dec 25, 2003 | 12:58 AM
noble4ws's Avatar
i was just looking at the shocks and springs and i noticed that with the rear when i put the spring on the shock the right way the spring is kinda sloppy on the shock but if i turn it upside down it fits perfect? kinda strange i think
Old Dec 25, 2003 | 06:25 AM
JG Luder's Avatar
Default Re: shock and spring install (noble4ws)
I've been meaning to do a writeup about that. Hmmm... wonder if we still have all those pics?
Old Dec 25, 2003 | 02:24 PM
iam7head's Avatar
Default Re: shock and spring install (Lone Luder)
dont need no stinkin' air tool
consider I am 5'10 155lbs and i can still can get my spring and shocks replace in my garage
socket wrench, hex key, breaker/cheater bar, wd40, spring compressor, jack and jackstand and a friend would be perfect for the job.
dont forget to mark the spring and shock with white-out first
Old Dec 25, 2003 | 06:00 PM
noble4ws's Avatar
bump, any ideas on the reason for them being sloppy
Old Dec 25, 2003 | 06:55 PM
iam7head's Avatar
Default Re: (noble4ws)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noble4ws &raquo;</TD></TR><TR><TD CLASS="quote">bump, any ideas on the reason for them being sloppy</TD></TR></TABLE>
huh? i dont get it
Old Dec 25, 2003 | 09:47 PM
noble4ws's Avatar
when i put the rear spring on the shock the base of the spring and where it sits on the shock dont match up perfectly but if i turn the spring upside down it works perfect
Old Dec 26, 2003 | 12:50 PM
LudeyKrus's Avatar
Default Re: shock and spring install (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
dont forget to mark the spring and shock with white-out first</TD></TR></TABLE>
Why would yo do that?
I've done 3 cars so far, and even though an impact wrench isn't necessary, it makes life a LOT easier!
Old Dec 27, 2003 | 01:49 PM
OTT's Avatar
OTT
makavelli1227
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">airtools are your friends.</TD></TR></TABLE>
Wrong
LudeyKrus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">even though an impact wrench isn't necessary, it makes life a LOT easier!</TD></TR></TABLE>
Wrong It may make life much 'quicker' but can seriously effect the cars handling. Maybe not that much on just a coilover but the manufacturer spent time to ensure everything was bolted together with 'ideal' torque specs; so why overtighten then with force?
Buy yourself a torque wrench and use the proper torque specs. They're there for a reason.
Strut Fork-to-control arm nutt 48 Ft. lb
Aslo if relevant to your aftermarket equip..
Strut Fork pinch bolt 33 Ft. lb
Strut assembly shaft nut (stock unit) 22 Ft. lb
Hope that helps
Old Dec 27, 2003 | 01:50 PM
OTT's Avatar
OTT
same for both front and rear by the way
BB6-213
Honda Motorcycles
Nov 28, 2008 12:28 PM
91tegra07
Suspension & Brakes
11
Feb 12, 2008 01:28 PM
meangreenEG
Suspension & Brakes
Jul 10, 2007 05:41 AM
Team Bukkake Sucks!!!
Jun 13, 2006 09:28 AM
noble4ws
Dec 25, 2003 05:43 PM
