Starting problems
Old May 27, 2004 | 05:57 PM
Pr0jektLude's Avatar
Default Starting problems
I have a f22a, im not sure if anyone esle as the same problem as me...but like sometimes usually around summertime like right now, If my car sits to long it dosent like to start. Today i sat in the school parking lot cranking it, but it was about 20 minutes before it finall started up....any suggestions on what this could be?
Old May 27, 2004 | 06:00 PM
Daboi630's Avatar
don't know but my friend has an old accord with the same problem. doesnt start in the heat. :shrugs:
Old May 27, 2004 | 06:11 PM
junbb1's Avatar
Default Re: Starting problems (Pr0jektLude)
MAIN RELAY.
hit the drivers side of the dash when it wont start. with the door open near your ac outlet vent. it should crank right up after a couple of hits. the solders crack in the relay and they expand in the heat.
Old May 27, 2004 | 06:28 PM
Default Re: Starting problems (junbb1)
alright thanks, ill try that next time... cause i dunno that really pisses me off when it dosent like to start. I also heard it could be from not gettin fuel? but i just recently replaced my fuel filter, but could my fuel pump be bad?
Modified by Pr0jektLude at 7:41 PM 5/27/2004
Old May 27, 2004 | 07:32 PM
junbb1's Avatar
your main relay is the relay that supplies power to your fuel pump. no power=no fuel=no start.
White98LS
Jul 14, 2007 07:46 AM
RuskeR
Nov 15, 2006 08:30 AM
go4wheeling
Sep 18, 2006 03:43 AM
uszcrx
24
Sep 9, 2006 01:05 PM
AgentJam
Aug 15, 2004 03:07 PM
