about the prelude...
Old May 21, 2004 | 06:53 AM
Thursty's Avatar
Default about the prelude...
im thinking about gettin a prelude. right now im pimpin an ES3 Lexus. I'm looking at buyin a 97-01 prelude and i had a couple questions.... First, should i get a base or SH and what are the differences? Second, What are some things i should look for or being cautious of when looking at this car? Third, what does this car run stock with a good driver? Thanks..
Old May 21, 2004 | 06:58 AM
GaRn's Avatar
hey, I would recommend the base model if your looking for any serious power down the road, if your just wanting a great daily driver, with little mods, go for the SH model. The SH has a system called atts, its not a limited slip differential but works by splitting up the power transmitted to each of the front wheels based on all kinds of variables.
the SH weighs a little more(like 88 lbs or so), and both should run high 14's granted its a manual.
Just check for things you would check on any other car, preludes dont really have any problems, just make sure there are no grinds in teh tranny etc.. try to get one that has been MAINTAINED!
good luck!
Old May 21, 2004 | 07:03 AM
Thursty's Avatar
Default Re: (GaRn)
alright so yeah im prolly gunna be lookin at the base model. can you tell me why i would want to go with the base model for aftermarket accessories and mods? also, what is the deal with H22, H23?
Old May 21, 2004 | 07:30 AM
98TypeSH's Avatar
Default Re: (Thursty)
H23 really only applies to 4th gen ludes. Its a non vtec torqe monster. H22 is the 2.2L Vtec that is in all 5th gens. I think anything after 98 has a little bit more HP to the wheels due to some late changes. The only thing wrong with the type SH, is that if you are going for SERIOUS power, like in upwards of 300, ATTS just becomes dead weight, and the only real way to get rid of it is a tranny swap. if you are more into auto-X then ints all good. the SH mods are usally a little bit more expensive, in terms of clutch, exhuast, suspension, headers, those sort of things.
drive both, take some bat turns, and decide if you are going turbo or N/A.
Old May 21, 2004 | 07:51 AM
AndyD's Avatar
Default Re: about the prelude... (Thursty)
https://honda-tech.com/zerothread?id=833304
Old May 21, 2004 | 08:12 AM
preludeez's Avatar
Default Re: about the prelude... (AndyD)
buy the base
Dev893
Sep 8, 2017 06:03 PM
smoothe
Jul 16, 2007 09:49 AM
Ironmaidenkicksa$$
Jan 26, 2006 08:27 PM
GettaluvR
Aug 15, 2001 02:04 PM
