SPEEDOMETER HELP
Old May 25, 2004 | 05:41 PM
hieu512's Avatar
Default SPEEDOMETER HELP
for some reason my speedometer keep on going up and down on my 92 prelude, i swap an h22 engine it, maybe a wire is loose not sure if anyone know how to fix it or what wire i should check let me know thanks you---exp going on 60-shift to 3 gear the speedometer go back to 0 until i hit the gas then it contiune where it left off....please help
Old May 25, 2004 | 09:29 PM
Kal's Avatar
Kal
Default Re: SPEEDOMETER HELP (hieu512)
check if you damaged your VSS sensor.
edit: and the speedo cables.
integra_101
Aug 18, 2013 04:15 AM
silencedogood
Jan 3, 2012 04:11 AM
that-guy
Welding / Fabrication
17
Jun 20, 2011 06:16 AM
dc2much
Apr 7, 2008 03:58 PM
assessino0054
Nov 13, 2004 03:41 PM
