Engine problem
Old Aug 17, 2004 | 08:47 PM
esca's Avatar
Default Engine problem
Hi,
I was driving to the dmv to register my prelude (i bought it like 5 days ago) h22a with lsd tranny, and as im looking for parking, because its such a bitch over there, i stop, because soemones backing out.
as i stop, my rpms shoot down to 0 (clutch in, gear 1) and the car dies out on me. i thought i stalled or something, but i notice my clutch is in. i try starting the car, but nothing.
ended up registering my car, but getting it towed to a mechanics. charging me 100 for a diagnostic check.
but i would like to know, if any one of you had the same problem or anything with the engine.
when i try and start it up, it seems liek the battery is working fine, and everythign is rotating correctly, but i cant seem to get it to 'catch'.
any help on this would be appreciated
thanks
Old Aug 17, 2004 | 10:16 PM
esca's Avatar
Default Re: Engine problem (esca)
any ideas?
even guesses?
Old Aug 17, 2004 | 10:33 PM
BrokeLude's Avatar
At this point it could be so many things. You need to start with the basics, which are making sure you have fuel and spark...
Old Aug 17, 2004 | 10:49 PM
esca's Avatar
alright.
thanks for the help
Old Aug 17, 2004 | 11:29 PM
Zehaus's Avatar
yeah dude i have the same problem in my 92 h23a
it seems to happen more often when im facing up a hill but.. it still happens on occasion when im down hill or flat. I'm probably gonna replace my spark plugs and hope for the best
Old Aug 18, 2004 | 01:27 AM
OEM_ASSASSIN's Avatar
Default Re: Engine problem (Zehaus)
I have had the same problem with both of my motors, F22A1 and H22A. Happens more often when it is hot outside. It seems to be a problem that a lot of preludes have. If I let it sit for a while it will start right up.
Old Aug 18, 2004 | 08:24 AM
93H22ACX's Avatar
Default Re: Engine problem (OEM_ASSASSIN)
yeah could be alot of things....but you might want to check the ignitor or coil....
my old prelude vtec died on me a couple of times when drivnig and when i try to start it just cranks like it wants to start but doesnt...
first time it was a dead coil, second time was a dieing ignitor...
Old Aug 18, 2004 | 08:32 AM
98TypeSH's Avatar
Default Re: Engine problem (93H22ACX)
also check your main relay!!!!!! The solder connections could be cracked and not making proper contact. usally hot temp makes this thing more intermitent if its worn. what gen car do you have esca ?
Its usally a problem in 4th gens. With 5th Gens they did a recall on the ignition "barrel" . It would cause the car to shut off while on a freeway or just driving around.
Modified by 98TypeSH at 9:45 AM 8/18/2004
Old Aug 18, 2004 | 08:50 AM
esca's Avatar
h22a 92 s
the battery seems to be fine, and everything else like the starting motor and the bands seem to be turning, it is just not catching on
ill be awating the mech though.. see what he says..
thanks for the help though, appreciated
Old Aug 18, 2004 | 08:53 AM
93H22ACX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">
exactly what mine did as soon as the engine was warm enough the car would die. let it cool off then starts right up.
98TypeSH's Avatar
alrighty, let me know when the mechanic cant figure it out.
Old Aug 18, 2004 | 10:19 AM
esca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93H22ACX &raquo;</TD></TR><TR><TD CLASS="quote">
exactly what mine did as soon as the engine was warm enough the car would die. let it cool off then starts right up.</TD></TR></TABLE>
wouldnt that mean you can never drive in warm weather?
lets say you go to work or school or something, and its a blazing 90+ degrees outside, when you get back to your car to go home, it wont start =p
what did you do to fix it, 93h22acx?
Old Aug 18, 2004 | 10:29 AM
esca's Avatar
well the mech called, and said it was teh distrubitor.. and his quote is 629 for parts and labor..
i was thinking about doing the job myself, but ive never really work indepth on an engine before.. can someone tell me if its worth it?
thanks
Old Aug 18, 2004 | 10:32 AM
93H22ACX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esca &raquo;</TD></TR><TR><TD CLASS="quote">
what did you do to fix it, 93h22acx?</TD></TR></TABLE>
replaced the ignitor and worked perfectly but rev started being irratic so no vtec....it was the magnetic pick up...so i bought a new distributor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esca &raquo;</TD></TR><TR><TD CLASS="quote">well the mech called, and said it was teh distrubitor.. and his quote is 629 for parts and labor..
thanks</TD></TR></TABLE>
just buy a new distributor from distributor king or buy a used one....if it is the distributor just unplug the two plugs and remove the the 3 bolts and then pull it out. installation is in reverse order with the exception of lining up the distributor shaft to the camshaft and use a timing gun.
Old Aug 18, 2004 | 10:37 AM
93H22ACX's Avatar
if you need a manual check my sig
Old Aug 18, 2004 | 10:38 AM
esca's Avatar
Did you install your distributor by yourself? or did you ahve it done by a mechanic.. i seirously dont want to pay 629 + 100 after i just bought the car.. if you did chance the dist.. how hard of a job was it?
thanks
Old Aug 18, 2004 | 10:39 AM
93H22ACX's Avatar
install by myself.
its not hard
Old Aug 18, 2004 | 03:31 PM
limpmode's Avatar
i hope you slapped the mechanic in the face. that's a 20 min job. kinda like my friend who paid $400 to put on an alternator in a jeep.
trololog
Jun 19, 2013 07:03 PM
Enzo15
May 31, 2011 06:31 PM
SnowSurfer
Apr 25, 2005 02:08 AM
psilo
Sep 16, 2004 11:40 AM
GSRwBOOST
Jun 4, 2002 01:41 PM
