Help Me
Old Aug 15, 2004 | 10:54 AM
Carbon_Lude98's Avatar
Default Help Me
sup guys,
i have a huge problem.
the other day i was getting on the interstate, i was coming downt the on ramp, and i was about 6200 rmps in 1st, when all the sudden it stoped givin me power (much like a rev limit) after i saw it was not going, i switched to 2nd and got a nasty bog..and my check engine light flashed on...now almost every time it gets to 6500 rmp(in 1st reved in nutral) the cars power cuts out..or it feels like its haveing trouble geting power..i checked the code on the check engine light it said "air fuel meter"..
any body knows what wrong.?.
Old Aug 15, 2004 | 11:21 AM
Shakes's Avatar
space cadet
Default Re: Help Me (Carbon_Lude98)
1 - be happy anyone read your thread. next time make the title into something better then "Help me". i.e. Air Fuel problem or code xxxx.
2 - what is done to the car
3 - what year, model
4 - when is the last time the fuel filter was changed
5 - do you ride with a low tank of gas a lot? if so STOP that ****.
6 - in your engine bay find the fuel pressure regulator. is there a vacuum hose attached to it? if not, find where the hell that went and attach it.
something in your air fuel mixture has gone bad. your car is in limp mode and will not switch to the high lobe fuel map.
Old Aug 15, 2004 | 02:06 PM
Default Re: Help Me (Shakes)
1-ok, sry man im new...(about title)
2-nothing, its bone stock h22a4
3-1998, base
4- ive only had the car for 3 mounths, and ive never had it changed
5- i have a few times, and i will stop now.
6- hose is attached
took to a guy that works on imports, he told me that if im not in any gear and i rev the car and it stops right at 6500. then i have ether faulty igntion or ecu. is that true?
Modified by Carbon_Lude98 at 3:18 PM 8/15/2004
Old Aug 15, 2004 | 02:22 PM
SuperSlow's Avatar
Change the fuel filter. if you do it yourself, you will facilitate the process significantly with the purchase of a crow's foot flare wrench 14 mm..
Also, check your plugs color.
Then the function of your fpr and fuel pump.
Then injectors.
Old Aug 15, 2004 | 05:05 PM
Filthy Focker!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">Change the fuel filter. if you do it yourself, you will facilitate the process significantly with the purchase of a crow's foot flare wrench 14 mm..
Then injectors.</TD></TR></TABLE>
No no, and no...
If your cel lit up, grab the codes dude.... Come back here with them..
fs
Old Aug 15, 2004 | 07:28 PM
ok, i dont know the code by # but i know that it translated to "fuel air meter" in the book.
also, i check my oil(cause the oil light came on) it was a little low,probly could use a change even though it only has 2300 mils on it...but the bigger thing is it smelt very rich...like it was mixed with fuel...so im thinkin head gasket now...
norcalimports
Sep 23, 2010 11:50 AM
ahtublao
29
Feb 23, 2010 08:21 PM
ek_sleepr
18
Feb 20, 2009 10:38 AM
weirdone86
Sep 14, 2006 07:35 AM
GTEC913
Jun 1, 2005 12:13 AM
