injector help!!!
Old Feb 22, 2012 | 07:24 AM
Eze209's Avatar
Default injector help!!!
need some help here...been tru a lot of forums and no clear answer at all...do h22a4 injectors use a resistor box? half the people say yes and the rest no...im in process of h22a4 swap into a crx...
Old Feb 22, 2012 | 08:27 AM
bigblue7t6's Avatar
Default Re: injector help!!!
H22a4 injectors are high impedance, no resistor box.
Old Feb 22, 2012 | 08:31 AM
bigblue7t6's Avatar
Also as a last check if you are not 100% sure of the source of the injectors, you can measure the resistance between the posts of the injectors. Around a 3 ohm resistance means low impedance, a reading around 12 ohms means high impedance
Old Feb 22, 2012 | 10:12 AM
Eze209's Avatar
Ok got it. So no resistor box. Ill eliminate it today since i been having low idle problems. Would this be the reason on why motor turns on and kinda bogs downs on lower rpms? Btw im using a p28.
Old Feb 22, 2012 | 11:26 AM
bigblue7t6's Avatar
Yeah I would imagine it would interfere and I also believe I had read that it would somewhere. In theory it should. I had recently posted almost this same exact question about a week ago and it got moved to engine management. I am also having rough idle issues with my car on my chipped p28 in my 01 lude h22a4, I think it has to do with the tune though. I have contacted the company I got my basemap from and they are sensing me a tweaked basemap to see if it improves idle, my idle is very lopey, bounces consistently from 600 to 900 rpm and if I give it throttle and let off it dies.
Old Feb 22, 2012 | 07:48 PM
Eze209's Avatar
Huge difference, removed resistor box and ran smoothly. finally got to test drive it a little bit, but now there is lag on the throttle response...
accord2civic2prelude
17
Feb 4, 2010 09:23 AM
schock3
Aug 25, 2009 12:37 PM
lsturbo*
Aug 15, 2009 08:50 PM
rick_rabies
Jun 1, 2009 09:31 AM
rick_rabies
Engine Management and Tuning
Jun 1, 2009 07:52 AM
