A ECU Question
Old Mar 20, 2012 | 02:25 PM
JusAccord's Avatar
Default A ECU Question
Can a ECU go bad and can be check if its working?
99 honda prelude h22a4
Old Mar 20, 2012 | 02:31 PM
andoxviii's Avatar
Default Re: A ECU Question
Yes it can go bad.
The easiest way to test would be to borrow another ECU to test, or test yours in another car.
Old Mar 20, 2012 | 02:36 PM
JusAccord's Avatar
Originally Posted by andoxviii
Yes it can go bad.
ok thanks
Old Mar 20, 2012 | 02:42 PM
JusAccord's Avatar
my prelude is a 5speed, does it matter what kind of ecu i would need to get?
Old Mar 20, 2012 | 04:17 PM
andoxviii's Avatar
Yes, it also has to be from a manual.
Old Mar 20, 2012 | 04:46 PM
jdm_rb20's Avatar
Google "honda immobilizer" and find out if your car is equipped with the immobilizer. If it has an immobilizer, i think you might be unable to just "swap in an ecu" because the immobilizer system is tied in with the ecu and every component has to be factory-programmed to match each other.
come to think of it....just a shot in the dark, but if you have having "no-start" issues, then the immobilizer system might be relevant to your problem...
--TJ
Old Mar 20, 2012 | 04:50 PM
andoxviii's Avatar
--TJ
Ah, silly me. You're right.
Perhaps to test the ECU it may be best to have a friend's P13 handy. Of course you would need a conversion harness though...
Old Mar 21, 2012 | 02:45 PM
JusAccord's Avatar
--TJ
will do, good information, thanks, but I'm also gavin a hard time finding the same ECU i have online. i may probably can't buy the same one...
Old Mar 21, 2012 | 02:48 PM
JusAccord's Avatar
and yes I'm having "no start issues"
integra15
Jun 8, 2017 10:49 AM
whited
Jun 24, 2010 01:31 PM
JBirch_97Prelude
Sep 29, 2008 06:43 PM
brownman72000
Jul 11, 2003 08:01 AM
