Replacing Engine Variable Timing Solenoid Gasket
Old Mar 7, 2012 | 09:58 AM
caliskier's Avatar
Default Replacing Engine Variable Timing Solenoid Gasket
Looks like my engine is leaking oil from the gasket on the variable timing solenoid. Looks like a pretty simple thing to replace (the gasket). Here is a picture of the solenoid and gasket for the Accord, I have a prelude, but it is the same concept I think...
http://www.autopartsnetwork.com/cata...nda_year:1999_
Question 1: Do you need to add any kind of gasket sealant or hondabond when I put the new gasket on?
Question 2: Since this is a "timing" solenoid I question if there is a special way to install it such that installing it wrong will effect timing, like with the distributor, or can I just stick it back on there.
Thanks in advance.
Old Mar 7, 2012 | 10:03 AM
97ludedude's Avatar
Default Re: Replacing Engine Variable Timing Solenoid Gasket
vtec solenoid gasket. no sealant, you do not want anything to squeeze out and stop up the screen in the gasket. There is no special way to install it. Unbolt the solenoid change the gasket, reinstall. three bolts piece of cake.
Old Mar 7, 2012 | 06:28 PM
TheJGB3's Avatar
If you have an H22A, H22A1, or an H22A4 here is the part#
15825-P13-005 FILTER ASSY., SPOOL VALVE $13.65
http://www.hondapartsnow.com/genuine...5-P13-005.html
and here is the part# for the gasket on the top too
36172-P08-015 GASKET, SOLENOID BASE $5.65
http://www.hondapartsnow.com/genuine...2-P08-015.html
Old Mar 7, 2012 | 06:34 PM
caliskier's Avatar
Squeeze out?
Thanks for the help
Old Mar 7, 2012 | 06:38 PM
caliskier's Avatar
Thanks a lot!
This is the part I ordered from majestic... 15825-P13-005
part 16 on this page:
http://www.hondaautomotiveparts.com/...R+HEAD+%283%29
I thought it was both pieces.
Old Mar 7, 2012 | 07:11 PM
Wing8806's Avatar
by squeeze it - he means any form of liquid gasket getting into the screen. Thats why you just use the standard gasket and nothing more.
Old Mar 8, 2012 | 01:46 PM
TheJGB3's Avatar
Originally Posted by caliskier
Thanks a lot!
you should have ordered #16 & 18
Old Mar 12, 2012 | 08:42 AM
razorlude's Avatar
i would like to suggest use some liquid gasket on the outer ring of the gasket not the inner(to avoid any blockage like what 97ludedude said) then only it'll be settled once and for all.
Took me 3set of ori honda part to learn this nasty little gasket do like to play trick with us by keep on leaking,there's more than 50psi of oil pressure that try to get thru it man...
Old Nov 26, 2012 | 01:51 PM
96-h22a1's Avatar
Bringing this thread up again to say thank you for the information listed. Ordered my 2 gaskets from majestic honda about 30 seconds ago
airikkCRX
Jan 25, 2024 03:11 PM
NC_jdmeg
Feb 11, 2015 04:30 AM
journeyquest
Sep 3, 2010 12:39 AM
ezza
Nov 5, 2009 02:27 PM
95LssTeg
May 18, 2006 06:26 PM
