Camber kit & suspension problem
Old Jan 6, 2006 | 05:39 PM
co_seem's Avatar
Default Camber kit & suspension problem
Hi guys,
I just got a 97 prelude SH and it's lowered with eibach prokit. But it is seemed that the front is much lower than the rear. The previous owner told me because of the front has broken struts that make the front of the car lower than the rear. So I ordered a new set of KYB AGX. And today when I changed the oil my self, I found out that my front tires has inner camber wear. So, now I am thinking about buying front camber kit. I also found that the tires rubbed the fenders. Here're my question guys, and I prolly you guys can help me out:
1. Is it true that if the struts were broken, then the car will be a little lower?
2.Do I need a camber kit for car that's lowerd w/ Eibach prokit & KYB AGX setup?
3. Will alignment or camber kit helps to avoid the rubbing?
Thanks in advance for the help.
Old Jan 7, 2006 | 10:09 AM
1GPlusSH's Avatar
Default Re: Camber kit & suspension problem (co_seem)
Yes.
Most likely, yes.
Most likely, no.
Struts add to the stiffness of your ride and if you have them set to stiff, if they're adjustable, then it will ride slightly higher.
You almost always need a camber kit when you lower your car.
It depends on where you're rubbing if the camber kit will fix the rubbing. Your camber would have to be pretty bad for it to make your tires rub.
Deo
12
Sep 15, 2005 09:49 AM
lazyxazianxboi
Nov 1, 2004 08:32 AM
pacman86
Jun 29, 2003 03:03 AM
lsvinny
Mar 14, 2003 05:50 PM
CC2
Dec 1, 2002 09:52 AM
