3rd gen: fault code 11?
Old Jan 12, 2006 | 01:30 AM
dave0000's Avatar
Default 3rd gen: fault code 11?
hey does anyone know what this code means i cant find it anywhere, the prelude is a 1988 Si model.
Old Jan 12, 2006 | 06:31 AM
kulrevon's Avatar
Default Re: 3rd gen: fault code 11? (dave0000)
check the code again I have a feeling its not an 11.
Old Jan 12, 2006 | 04:08 PM
dave0000's Avatar
Default Re: 3rd gen: fault code 11? (kulrevon)
um na its definately 11 short flashes, i know it sounds wrong but i checked many times, i changed the ecu from the original one but the one thats in there now is out of the exact same model, someone told me theres a difference in the new zealand new preludes as mine is an import, something about the air temperature sensor been replaced by a intake mixture adjuster, does this sound right to anyone?
Modified by dave0000 at 1:27 PM 1/13/2006
Old Jan 12, 2006 | 04:34 PM
SteveoBA8's Avatar
My usdm chiltons manual does not list a code 11, it lists cel code 10 as the AIT, air intake temp sensor.
Old Jan 12, 2006 | 04:37 PM
dave0000's Avatar
Default Re: 3rd gen: fault code 11? (SteveoBA8)
if i unplug the air temp sensor i get fault code 10 and 11 at the same time so it cant be that
Old Jan 12, 2006 | 04:43 PM
SteveoBA8's Avatar
must be because its imported, make sure you reset the ecu after you plug it back in and see if you get the same code.
Old Jan 13, 2006 | 12:26 PM
dave0000's Avatar
ive tried resetting the computer but it still throws the code, the engine check light is constantly on but the engine seems to run perfectly fine, anybody got any ideas?
Old Jan 13, 2006 | 02:22 PM
SteveoBA8's Avatar
Does the cel come on imediately after starting after you reset it? Its running in open-loop(pre-programmed info).
Old Jan 13, 2006 | 10:30 PM
dave0000's Avatar
the cel comes on as soon as the ignition is switched on and then the engine check light comes on once the cars started, i think it may be running a little bit rich as well
cklauj207
Oct 18, 2012 05:25 AM
msinsky14
Jan 6, 2009 07:44 PM
jdmazm
Apr 16, 2006 10:56 AM
Mattb16teg
Jan 25, 2005 05:51 AM
