Radiator Fan Control Module
Re: Radiator Fan Control Module (Kwaakku)
ABS Control Unit: Behind right quarter trim panel
ABS Modulator solenoid Unit: Right rear of engine compartment
ABS Motor: Right Rear of Engine Compartment
ABS Motor Relay: In under-hood fuse/relay box
ABS Pressure Switch: Right rear of engine compartment
ABS Front Fail-Safe Relay: Behind left side of dash
ABS Rear Fail-Safe Relay: Behind left side of dash
A/C Compressor Clutch: Left front of engine
A/C Compressor Clutch Relay: Left front corner of engine compartment
A/C Diode: Left front corner of engine compartment
A/C Dual Pressure Switch: Right front of vehicle
A/C Thermostat Switch: Behind right side of dash
Alternator: Left front of engine
Automatic Transmission Control Unit: At right kick panel
Auxiliary Fuse Holder: At left kick panel
Back Up Lights Switch: Right side of engine
Blower Motor: Behind right side of dash
Blower Motor Resistors: Behind right side of dash
Brake Light Sensor: Left rear corner of trunk
Blower Motor Relay: At left kick panel
Brake Fluid Level Switch (Inside): Left rear of engine compartment
Brake Light Switch: Behind left side of dash
Cigarette Lighter Relay: At left kick panel
Chime: At left kick panel
Clutch Interlock Switch: Behind left side of dash
Clutch Switch: Behind left side of dash
Condenser Fan Motor: Left front of engine compartment
Condenser Fan Relay: Left front corner of engine compartment
Coolant Temperature Sending Unit: Right side of engine
Coolant Temperature Sensor (TW): Right side of engine
Coolant Temperature Switch A: Right side of engine
Coolant Temperature Switch B: Right side of engine
Countershaft Speed Pulser (NC): Underside of vehicle, rear of transmission
Cruise Control Actuator: Left front corner of engine compartment
Cruise Control Unit: Behind left side of dash
Dashlight Brightness Control Unit: Right side of dash, behind display visor
Dimmer Relay: In under-hood fuse/relay box
Distributor Assembly: Right side of engine
Door Lock Latch Assembly (Behind): Rear of driver's door
Door Switch: Rear of driver's door area
Driver's Airbag Inflator: Center of steering wheel
EGR Control Solenoid Valve: Left side of engine compartment
EGR Valve Lift Sensor: Center rear of engine
Electric Load Detector (ELD) Unit: Bottom of under-hood fuse/relay box
Electronic Air Control Valve (EACV): Center rear of engine
Fan Timer Unit: Right front of floor, below carpet
Fog Light Relay: Behind left side of dash
Four Wheel Steering Control Unit: Behind left rear seat
Front ABS Speed Sensor: Behind left front wheel
Front Main Steering Angle Sensor: Left side of steering column
Front Sub-Sensor: Underside of vehicle, left side of steering gearbox
Fuel Injectors: Top center of engine
Fuel Pump: Below center of rear seats
Fuel Tank Unit: Below center of rear seats
Functional Control Motor: Behind left side of dash
Headlight Relay: In under-hood fuse/relay box
Heated Oxygen Sensor: Center front of engine
Horn Relay: At left kick panel
Ignition Coil: Right side of engine
Ignition Switch: Right side of steering column
Intake Air Temperature Sensor (TA): Left rear corner of engine
Intake Control Solenoid Valve: Right side of engine compartment
Integrated Control Unit: Rear of under-dash fuse/relay box
Interlock Control Unit: Above left kick panel
Key Interlock Solenoid: Right side of steering column
Key Interlock Switch: Right side of steering column
Knock Sensor: Underside of vehicle, center rear of engine
Left Dash Sensor: Left front of floor, below carpet
Left Horn: Center front of engine compartment
Lock-up Control Solenoid Valves - Automatic Transmission: Right front of engine
Mainshaft Speed Pulser (NM): Underside of vehicle, front of transmission
Manifold Absolute Pressure Sensor: Center rear of engine
Oil Pressure Switch: Underside of vehicle, center rear of engine
Parking Brake Switch: Below center console
Passenger's Airbag Inflator: Behind right side of dash
PGM-FI Electronic Control Unit: Right front of floor, below carpet
PGM-FI Main Relay: Behind left side of dash
Power Antenna Motor: Right side of trunk
Power Door Lock Control Unit: Front of driver's door
Power Steering Oil Pressure Switch: Underside of vehicle, behind center of engine
Power Window Motor: Middle of driver's door
Power Window Relay: At left kick panel
Purge Control Solenoid Valve: Center rear of engine
Radiator Fan Motor: Right front of engine compartment
Radiator Fan Relay: In under-hood fuse/relay box
Rear ABS Speed Sensor: Behind left rear wheel
Rear Main Steering Angle Sensor: Underside of vehicle, center of rear steering actuator
Rear Sub-Sensor: Underside of vehicle, center of rear steering actuator
Rear Window Defogger Relay: At left kick panel
Recirculation Control Motor: Behind right side of dash
Right Dash Sensor: Right front of floor, below carpet
Right Horn: Center front of engine compartment
Shift Control Solenoid Valves - Automatic Transmission: Right front of engine
Shift Lever Position Switch: Below left side of front console
Shift Lock Solenoid: Below right side of front console
Starter Cut Relay: At left kick panel
Starter - Manual Transmission: Right front of engine
Starter - Automatic Transmission: Right front of engine
Sunroof Open Relay: At left kick panel
Sunroof Close Relay: At left kick panel
Sunroof Motor: Center rear of ceiling
Supplemental Restraint System Control Unit: Below center of dash
Thermal Protector: Left front of engine
Throttle Angle Sensor: Center rear of engine
Trunk Latch Switch: Center rear of trunk lid
Turn Light Diode: At left kick panel
Turn Signal/Hazard Lights Relay: At left kick panel
Under-dash Fuse/Relay Box: At left kick panel
Under-hood Fuse/Relay Box: Right rear corner of engine compartment
Vehicle Speed Sensor: Right side of engine compartment
Wiper Intermittent Relay: Left rear corner of engine compartment
Windshield Washer Motor: Behind lower left side of front bumper
Windshield Wiper Motor: Behind left side of air scoop
i didnt really read through the list but i'm guessing that there is no radiator fan control module. its more than likely the pcm which controls a relay.
1 Post
Actually, I can tell you 100% for sure it's the little black box next to the ECU to the left and down. The ECU is under the dash on the passenger side behind a metal kick-panel.
Re: Radiator Fan Control Module (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">Actually, I can tell you 100% for sure it's the little black box next to the ECU to the left and down. The ECU is under the dash on the passenger side behind a metal kick-panel.</TD></TR></TABLE>
these are what controls your fans.
most likely a bimetalic type switch.
http://spaces.msn.com/members/...ner=1
Jeah, but that's not the thing. I've problem with my car. I connected two connectors wrong (orange and grey pair near under-hood fusebox) and now my gauge show that temperature is in maximum level, both fans are scrolling and engine won't start. Now i'm looking is there something broken in that part... If anybody have some good advices, just let me know...
Re: (Kwaakku)
I have a possible problem with mine, i have ripped out a P12 Auto ECU and put in a P13 Manual ECU, as i have changed the engien and gearbox. now i installed the complete loom from a JDM 93 model, into my AUDM 95 model. My issue is thus, the Radiator Fan Control has P12 stamped on the top of it, can i use it with a P13? And if so, where is it located in a 93 model, as i don't recall seeing a plug there for it.
BUMP
