SRS Reset Sequence needed
Old Jan 11, 2006 | 01:36 PM
Silver Surfer's Avatar
Default SRS Reset Sequence needed
anyone know how to do this.....my light came on after i reconnected everything and did not go off. for my 4th gen
Old Jan 15, 2006 | 11:06 AM
anyone know how to reset the srs light?
Old Jan 15, 2006 | 11:15 AM
Hawkze_2.3's Avatar
Default Re: SRS Reset Sequence needed (Silver Surfer)
The Helms says there is a Memory Erase Signal (MES) connector back behind the dash with the other service connectors. It has light green/black and black wires coming from the back of it. Bend a paperclip or something like that to connect both terminals on this connector and flip the ignition switch on. The SRS light should come on for 6 sec. and then turn off. Remove the paperclip within 4 seconds of the SRS light going off. Then it will come on again, and you need to connect the terminal again within 4 seconds. Then it will turn off again, and you need to remove the paperclip within 4 seconds again.
Finally the light will blink 2 times indicating the memory is erased.
Sorry, I didn't know that would be so damn complicated, I just wrote what's in the manual ...
Old Jan 15, 2006 | 04:47 PM
haha thanks....i will try that tomorrow
Old Jan 16, 2006 | 09:18 AM
where in helms is it....i can't seem to find the mes connector
Old Jan 16, 2006 | 10:32 AM
Hawkze_2.3's Avatar
Default Re: (Silver Surfer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silver Surfer &raquo;</TD></TR><TR><TD CLASS="quote">where in helms is it....i can't seem to find the mes connector</TD></TR></TABLE>
In the end with the electrical stuff. It has a picture of a battery with 'SRS' written on it.
Old Jan 16, 2006 | 11:53 AM
i'm still not seeing it anywhere.....
is it labeled MES?
it's 2pin right?
luis_ej8
Honda Fit
Jan 8, 2024 11:12 AM
undrh2o
10
Dec 19, 2009 11:42 AM
rmk9785e
Sep 30, 2007 09:49 AM
DumpedSi
Sep 11, 2003 08:42 PM
mrlegoman
Oct 25, 2001 05:20 AM
