Problems With My ECU
Old Jan 11, 2006 | 05:03 PM
kelvinchau25's Avatar
Default Problems With My ECU
Okay, I'm running the stock ECU right now in my 2000 Prelude SH.
I just installed a test pipe and now my Check Engine Light is on (No Surprise).
Now because my check engine light is on my ATTS is disabled 24/7.
I'm looking for some kind of solution where I can run the test pipe and not have the check engine light on or the ATTS disabled. What can i do? Did some research on Hondata.com and they said that all their chips result in the loss of the ATTS.
Is there any JDM ecu I can pick up that would eliminate the check engine light problem and allow my ATTS to work and also which I can eventually dyno tune after I boost my car?
If not are there any other solutions to help me with this problem?
Thanks for reading.
-Frosty
Old Jan 11, 2006 | 09:10 PM
A Blue Lude's Avatar
Default Re: Problems With My ECU (xxxdjfrostxxx)
Search around for O2 simulators, they provide what you need.
There are two basic kinds of simulator. Electronic ones simulate a secondary O2 sensor seeing what it should see. Mechanical ones remove the O2 sensor from the exhaust gas flow so it doesn't trip a CEL.
I'd go the mechanical path, personally. These two links describe a pretty good (and cheap) method.
http://www.7thgencivic.com/for...unt=1
http://www.s2ki.com/forums/ind...lator
JDMEF
Apr 3, 2012 11:32 AM
luvinmyGSR
Aug 26, 2004 08:27 PM
94civicx
Aug 7, 2002 03:50 PM
sivicman
May 15, 2002 01:17 PM
Pure R Racer
Nov 28, 2001 06:33 PM
