electrical problem need help???
Old May 4, 2006 | 08:42 PM
reAper86's Avatar
Default electrical problem need help???
k i have a 97 lude
when its on idle the battery is draining until 11.8 volts
but once i step on the gas it start charging up to 13 to 14 volts
got my alternator check and its ok
fuse ok
battery ok
wats next? short on wire harness????or open??
Old May 4, 2006 | 09:00 PM
prelude1897's Avatar
Default Re: electrical problem need help??? (reAper86)
ummm, your battery is fine....When you're gassing it, yeah your battery is being charged cause you're turning the alternator which then charges up your battery, which then will push out more voltage
Old May 4, 2006 | 10:35 PM
reAper86's Avatar
Default Re: electrical problem need help??? (prelude1897)
no but it wont power my audio system
and during night time when its draining the headlights are dim
when i gas it they are bright
Old May 5, 2006 | 02:30 AM
onefastrx7turbo's Avatar
is it 11.8V with your system on? if so the stock charging system wasnt designed to handle the extra load
Old May 5, 2006 | 03:18 AM
mgags7's Avatar
how much audio crap do you have??
what size battery is it?
Old May 5, 2006 | 02:51 PM
reAper86's Avatar
Default Re: (mgags7)
just 400 watt amp
2 10" thats all
12v battery
mydogFahey
Honda CR-V & Element
10
Mar 29, 2015 09:59 AM
Einhander276
Dec 7, 2012 04:28 PM
Tommy_Gunns
Sep 11, 2009 12:10 AM
gsrpedro
14
Feb 5, 2008 01:14 PM
tC_Dragon
Feb 23, 2003 02:36 AM
