92 Master Window Switch Problem!
Old May 8, 2006 | 07:34 AM
tacticalcustoms's Avatar
Default 92 Master Window Switch Problem!
Alright. a couple months ago I came home. parked my car and rolled up my window's via master window switch(driver side). well the next day I come out. and my driver side window rolls down fine. but when I used the passsenger switch onthe master switch it wouldn't rolldown the passenger side window.. but whenI use the window swithc on the passenger side of the car.. the window rolls up and down fine.. well now common sense kicks in right.. it has to be that the master window switch is broken and I should go pick up a new one...
well after 3 master window switch's and still no luck with the passenger switch on it to roll down my window I decided to check all the wiring.. the fuses are fine. checked them. the relay works perfect..
when I check the passenger side wiring.. I got a positive read from the main fuse wire that goes to the switch.. when I used the passenger side switch and roll up and down the window. I get a postive read from both wires that roll up the window. but the other 2 remaining wires onthe switch are the wires that come from the master switch.. when I try and use the switch I get no positive input.. I dunno if this makes alotof sense. but maybe someone will know whats up..
Old May 8, 2006 | 10:38 AM
Default Re: 92 Master Window Switch Problem! (tacticalcustoms)
bump
Old May 8, 2006 | 04:39 PM
darkspector's Avatar
can you get a reading on those 2 wires from the master side
Old May 11, 2006 | 06:03 AM
Default Re: (darkspector)
I get a read from the fuse wire on the master side. but not the 2 wires that go to the passenger side when I push up and down on the switch.
Old May 11, 2006 | 07:33 AM
Eksmashin23's Avatar
bump.
Old May 11, 2006 | 11:03 AM
jaybees's Avatar
have you tried replacing the passenger switch? The signal to roll up and down the window goes from the master switch through the passenger switch. If you look at the wire diagram in the helms you will see that. You can test the passenger switch by removing it and jumping the appropriate wires (thus bypassing the switch) then see if the master control works.
Old May 11, 2006 | 01:05 PM
cool. I check it right now.. thanks
92cxhatch169
Mar 21, 2011 06:49 PM
runninclean
Mar 29, 2010 02:15 PM
ramoneguru
May 20, 2006 02:47 PM
berge
Apr 2, 2006 09:59 PM
92ehatch
Mar 3, 2006 02:49 AM
