VTEC Controller
Old May 6, 2006 | 10:13 AM
EliTe 93Lude's Avatar
Default VTEC Controller
I did a little searching around here and didn't find anything.
Anyhoo, I have been hearing mixed reactions on VTEC controllers. Some say good and some say waste of money. From anyone that has one or knows a thing or two about them, is it worth the money?
Old May 6, 2006 | 10:32 AM
Default Re: VTEC Controller (EliTe 93Lude)
*Bump*
Old May 6, 2006 | 10:42 AM
InvaderTrax's Avatar
Well, think of it this way. Honda puts millions of dollars into research to find the best point for VTEC to engage. Why would you wanna mess with that? If your engine is heavily modified, there may be a better place for VTEC to engage, but in the average I/H/E H22, stock engagement point is the best place
Old May 6, 2006 | 12:00 PM
oranginal's Avatar
i have a vafc but i am getting cams installed and wated to have aometihng to tune with b4 i put them in.
if u r using turo go hondata.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">Well, think of it this way. Honda puts millions of dollars into research to find the best point for VTEC to engage. Why would you wanna mess with that? If your engine is heavily modified, there may be a better place for VTEC to engage, but in the average I/H/E H22, stock engagement point is the best place</TD></TR></TABLE>
honda also didn't want vtec to engage too early, otherwise u'd be in vtec more often and burning oil more ofter.
Old May 6, 2006 | 12:31 PM
Default Re: (InvaderTrax)
What about if I ony set it to engage at around 4000 RPMs? Would this be doing any "damage"? What about 3500 RPM?
Old May 6, 2006 | 01:32 PM
CAN97SH's Avatar
Resident Hoser #1
Community Builder
Community Influencer
Default Re: (EliTe 93Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EliTe 93Lude &raquo;</TD></TR><TR><TD CLASS="quote">What about if I ony set it to engage at around 4000 RPMs? Would this be doing any "damage"? What about 3500 RPM?</TD></TR></TABLE>
What about idle and that way you always have VTAC!!! Der
Old May 6, 2006 | 01:48 PM
Silver Surfer's Avatar
for the love of God don't set it below 4800-4900rpms, most people find that around 5100 is a good spot with minor mods.
you clearly need to do some more reading unless you were joking about those rpms
the reason people say vtec controlers are a waste is because they are only good for a small range of modifications....to little and they are not worth it, to many heavier mods and they are not letting you tune to your full potential.
Old May 6, 2006 | 02:17 PM
oranginal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silver Surfer &raquo;</TD></TR><TR><TD CLASS="quote">for the love of God don't set it below 4800-4900rpms, most people find that around 5100 is a good spot with minor mods.
X2
Old May 6, 2006 | 03:39 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: (oranginal)
You can't be serious!??!
Wow, I agree...I think you should set it to engage at idle...That way you always have that VTAK y0!
Old May 6, 2006 | 05:55 PM
tmoney1421's Avatar
Default Re: (AnthonyG2003)
you need to do a little more research on what exactly vtec is. there are reasons for vtec engaging at the right spot based on the timing of your engine. understanding the basic principles of vtec will help you out alot in determining whether you should significantly lower the engagement point or not. http://auto.howstuffworks.com/question229.htm is a great link to start out if you want to educate yourself.
Old May 8, 2006 | 11:50 AM
NAmodified's Avatar
Default Re: (tmoney1421)
my vtec kicks in at 5900, which i think is way to late. i want it at 5100-5200. Will i need a vafc to adjust the fuel and air at that rpm or can i just buy like a buddy club where it just sets the vtec timing?
Old May 9, 2006 | 08:37 PM
flipwhip's Avatar
Default Re: (NAmodified)
My engages at the stock 5200 I want to try it at 5000 just to see. I read some where that If you tune your car, it is good to have vtec engage so that you do not feel a big kick meaning you have a smoother poerband.Is this correct? I would rather it be that way, have almost the same amout of hp before vtec and just have a small increase.
Old May 15, 2006 | 11:44 AM
NAmodified's Avatar
Default Re: (flipwhip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipwhip &raquo;</TD></TR><TR><TD CLASS="quote">My engages at the stock 5200 I want to try it at 5000 just to see. I read some where that If you tune your car, it is good to have vtec engage so that you do not feel a big kick meaning you have a smoother poerband.Is this correct? I would rather it be that way, have almost the same amout of hp before vtec and just have a small increase.</TD></TR></TABLE>
yah, you want a smooth transition. my ecu is tunned for a fully built jun h22a. which is why mine kicks at 5900. i would want my vtec to kick in at 5000.
streetspeed607
Honda Civic (2001 - 2005)
Nov 21, 2007 12:35 PM
sluger17
20
Mar 22, 2006 08:28 PM
gsrwpower
Mar 21, 2006 09:50 PM
s2kDinesh
Honda S2000
12
Jan 10, 2005 12:27 AM
jammin civic
11
Oct 9, 2003 10:59 AM
