oil leak need help
Old Oct 11, 2006 | 02:48 PM
GsrIntegra789's Avatar
Default oil leak need help
hey guys...my friend has a 93 lude with an h22....he has an oil leak but we cant figure out where its comming from....i checked the oil pan no holes newhere...it kinda looks like its commin from the back of the block ...could it be that the oil sensor cracked or something like that? if anyone knows what it can be help is appreciated
Old Oct 11, 2006 | 03:03 PM
Jagan'92's Avatar
Default Re: oil leak need help (GsrIntegra789)
if it's only when the car is on it may be the oil cooler o-ring.
do a search in the prelude archives. it's between the cooler and the block. the cooler is what the filter screws onto. the o-ring costs maybe 3$
Old Oct 11, 2006 | 03:27 PM
Default Re: oil leak need help (Jagan'92)
no it leaks when the car is on i think there is a hose that goes from the cooler to the black can that be it?
Old Oct 11, 2006 | 07:26 PM
TheWalrus's Avatar
that hose carries coolant...the leak is from the o-ring under the cooler. take off the oil filter and the big nut on the stud it screws onto. very common prelude problem
Old Oct 11, 2006 | 08:27 PM
piggydog's Avatar
Default Re: (weenie)
if it drips on th pipe and smells really bad. It's the oil cooler.
Old Oct 11, 2006 | 10:48 PM
specialedition's Avatar
Default Re: (piggydog)
common problem on older honda engines... easy to fix though...
Old Oct 12, 2006 | 06:18 PM
Default Re: (specialedition)
today i saw that it doesnt come from the back of the block but comes from under the timing belt cover..i think it might be the oil seals by the crank what do u guys think....on preludes its really hard to see nething bc the motor is so close to the fenders i can barely fit a finger in there
JustCant5topMe
Aug 16, 2013 12:18 PM
bee20_vtec
Nov 19, 2009 05:00 PM
climb_on
Sep 30, 2007 06:48 PM
951dc5
Apr 19, 2006 05:06 PM
tur3oDC4
Mar 29, 2006 05:40 PM
