type s cams... what good do they do?
Old Oct 11, 2006 | 09:56 AM
JDMhondalude22's Avatar
Default type s cams... what good do they do?
i have a h22a... what good are these type s cams im hearing of? what years do they come from?
Old Oct 11, 2006 | 09:59 AM
MadCityLude
Guest
Posts: n/a
Default Re: type s cams... what good do they do? (JDMhondalude22)
96-00 JDM Type S Preludes. That would have been 97-01 here in the states. Cam profiles are slighlty higher performance.
I recomend aftermarket over the Type S due to the fact I have read that there could be clearance issues in a standard P13 head.
WhiteBB2's Avatar
Default Re: type s cams... what good do they do? (MadCityLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude &raquo;</TD></TR><TR><TD CLASS="quote">96-00 JDM Type S Preludes. That would have been 97-01 here in the states. Cam profiles are slighlty higher performance.
I recomend aftermarket over the Type S due to the fact I have read that there could be clearance issues in a standard P13 head.</TD></TR></TABLE>
x2
Old Oct 11, 2006 | 10:10 AM
Silver Surfer's Avatar
the clearance issues are not very different that any other after market cam
you just have to upgrade your valvetrain like you would with any other cam......and make sure the valvespring seats lower on the exhaust side so that the cam doesn't interfere with the rockers......
just make sure whoever installs them checks properly for clearance before they are done and maybe machine the rockers a bit
Old Oct 11, 2006 | 10:16 AM
MadCityLude
Guest
Posts: n/a
Default Re: (Silver Surfer)
^^ Thank you, I was actually kind of curious as to the exact problem and solution as to how to use them. Silver Surfer
Old Oct 11, 2006 | 12:23 PM
yeah i was interested in them a while back and did a lot of searching through all the threads....i've got a folder of about 6-7 threads saved under my favorites labeled "type s cams"........if anyone wants the threads with the important info without have to dig through the usless ones....pm me
that was basically what i came up with.......a lot of the problems came from people using them without upgrading the valvetrain.....or the install being done wrong because the installer figured they were an oem part and didn't get the clearance right
Modified by Silver Surfer at 3:14 PM 10/11/2006
Old Oct 11, 2006 | 01:55 PM
hu's Avatar
hu
You would be okay with a JDM H22, correct?
Old Oct 11, 2006 | 02:22 PM
i think the valve guide is still lower in the type-s than the regular jdm h22, but i could be wrong
i think if you are strapped for cash you can get away with just installing inner springs since those are the ones that need the height adjusted
oh and in response to the origional question what good are they....here is a comparison i found
Type S
Int- 309 mid Int- 230 mid Int- 469 mid
Exh-315 mid Exh-230 mid Exh-438 mid
Crower stage 2's.
Int- 311 mid Int- 255 mid Int- 468 mid
Exh-308 mid Exh-248 mid Exh-467 mid
max lift is actually higher than crower stage 2
Modified by Silver Surfer at 3:34 PM 10/11/2006
ee8_pt
K Series
Mar 11, 2011 04:30 AM
DCtooD
Oct 9, 2006 05:44 AM
Vb16a3
Sep 8, 2004 08:58 PM
