Model ?
Old Oct 10, 2006 | 03:14 PM
Ash81's Avatar
Default Model ?
Do the 97-01 Prelude Type SH........come in automatic & what's the difference in the struts/shocks (SH & base model)......im trying to buy some shocks/struts but in the description it says will not fit 97-01 SH model. Any input would be appreciated
Old Oct 10, 2006 | 03:21 PM
Revi's Avatar
Default Re: Model ? (Ash81)
All SHs are 5spd.
I believe almost every suspension part in the SH is different from the base. The Knuckel, radius rod, upper and lower control arms......what kinda shocks you looking at? I have Koni Shocks with Ground Control coil overs on my SH, all i needed was a special sleeve from groudn control if i remmember right.
Old Oct 10, 2006 | 03:23 PM
avallach's Avatar
SH does not come with an Automatic. Shocks/dampers for the Base Prelude may be used on the SH as long as you swap out the Springs, too. You can not use the OEM SH springs with Dampers made for the Base Prelude.
perry2929
Mar 11, 2014 09:21 PM
mafia
Jan 3, 2007 12:58 PM
Wet Nudl
Jun 27, 2005 04:35 PM
billk2k
Mar 31, 2003 01:08 PM
