h22 v-tec
Old Oct 11, 2006 | 06:12 AM
lsvtecndx's Avatar
Default h22 v-tec
i can take a stock ecu that crosses vtec at 4.9rpm and put it in my car and the vtec will cross at 6rpm no matter what i do.
Old Oct 11, 2006 | 06:18 AM
bluedlude's Avatar
Default Re: h22 v-tec (lsvtecndx)
do you mean 6000 RPM? take off the vtec solenoid and check it out. its got to be clogged or the actuator is broken.
Old Oct 11, 2006 | 06:39 AM
THC07's Avatar
Default Re: h22 v-tec (bluedlude)
most of the time your tach is just off. mine has never been real accurate
Old Oct 11, 2006 | 03:14 PM
lsvtecndx's Avatar
thanks
Old Oct 11, 2006 | 04:47 PM
JasonST's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC1107 &raquo;</TD></TR><TR><TD CLASS="quote">most of the time your tach is just off. mine has never been real accurate</TD></TR></TABLE> I don't think his tach is 1000+ rpms off, then again it's possible, but pretty unlikely.
Lsvtecndx are u getting a check engine light? Simple think to check first off is to try checking ur oil level too.
Old Oct 11, 2006 | 04:53 PM
99LudeDude's Avatar
did you try to go into VTEC in first gear only, or other gears also? You must be doing at least 20mph for VTEC to engage.
Old Oct 11, 2006 | 05:08 PM
.BigSexy's Avatar
most hood white kid
Default Re: (99LudeDude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99LudeDude &raquo;</TD></TR><TR><TD CLASS="quote">did you try to go into VTEC in first gear only, or other gears also? You must be doing at least 20mph for VTEC to engage.</TD></TR></TABLE>
yeah, my vtec engages pretty late in first gear, but in all others, right on the money, 5200 RPM
Old Oct 12, 2006 | 02:28 PM
lsvtecndx's Avatar
Default Re: h22 v-tec (JasonST)
oil levels fine no check eng.
Hatchman98
Jun 7, 2007 01:45 PM
jetlude
Feb 13, 2007 07:15 AM
lubmyinteg
Honda S2000
Feb 3, 2006 12:56 PM
My Db2 AinT JDM
May 18, 2004 09:24 PM
skafia
Jan 13, 2004 07:10 AM
