Removing ignition coil input plug
Old Oct 7, 2006 | 01:34 PM
vinuneuro's Avatar
Default Removing ignition coil input plug
The wire is so damn short. How do you disconnect the plug from the bottom of the coil?
Old Oct 7, 2006 | 02:01 PM
SteveoBA8's Avatar
Default Re: Removing ignition coil input plug (vinuneuro)
Push in on the tab, use a small flathead screw driver to depress the tap, when its depressed pull the plug out.
Joyfulchap
May 17, 2018 08:10 AM
rsanders21
Oct 25, 2010 05:19 PM
classic86crx
Feb 22, 2007 11:34 AM
JDMlyfestyle
Apr 25, 2005 01:12 AM
