injectors question
Old Feb 6, 2007 | 11:21 AM
preludefien
Guest
Posts: n/a
Default injectors question
on the bottom of the injector there is a plastic piece. if it is cracked then that means that the injector is of no use correct.
Old Feb 6, 2007 | 01:03 PM
preludefien
Guest
Posts: n/a
Default Re: injectors question (preludefien)
anyone
Old Feb 6, 2007 | 01:07 PM
mgags7's Avatar
the very tip is cracked?
Old Feb 6, 2007 | 01:09 PM
Speedra500's Avatar
it should still be ok, I believe it more of a guard to protect the pintle. If there is any different at all it would be the spray would be affected more by the incoming air affecting it sooner, although I doubt even that would be changed much
Old Feb 6, 2007 | 01:16 PM
preludefien
Guest
Posts: n/a
Default Re: injectors question (Speedra500)
yea the very tip were the needle is...
Old Feb 6, 2007 | 01:27 PM
preludefien
Guest
Posts: n/a
also is there anyway to tell the difference between h23 injectors and h22 stock oem injectors. ive heard that the h22 have the green plastic tips and the h23 have the yellow tips...is this so
Old Feb 6, 2007 | 05:48 PM
preludefien
Guest
Posts: n/a
any ideas
Old Feb 7, 2007 | 04:38 AM
preludefien
Guest
Posts: n/a
Old Feb 7, 2007 | 05:26 AM
Speedra500's Avatar
i think there are 2 blue dots on the OBD I h22 injector, I'm not totally sure on that so you would have to look into it, surely someone else knows
Old Feb 7, 2007 | 06:17 AM
preludefien
Guest
Posts: n/a
i know someone knows
Old Feb 7, 2007 | 02:52 PM
preludefien
Guest
Posts: n/a
Old Feb 7, 2007 | 07:08 PM
preludefien
Guest
Posts: n/a
come on someone knows
Old Feb 7, 2007 | 08:52 PM
mgags7's Avatar
Take a picture of them up close and post it....I'll compare to mine.
mondiex
May 28, 2012 09:55 PM
dickeytk
Aug 17, 2006 10:15 AM
yohan
Sep 27, 2004 08:33 PM
Hbgsr
Nov 7, 2002 05:21 AM
