injector cel
Old Feb 3, 2007 | 10:40 PM
preludefien
Guest
Posts: n/a
Default injector cel
i have the jdm h22a vtec. today i changed the injectors bc i figured the guy that helped me swap the h23 out used the injectors from the h23 so when i hooked up the p14 it ran in a limp mode. so you all suggested getting the stock injectors..so i get them and on the end the plastic peice at the bottom is cracked, making it unable to use..so i used 3 h22 injectors with 1 h23 injector along with the p14 ecu. does anyone know if it is bad for me to use the 3 h22 injectors with 1 h23 injector. the check engine light came on so im forsure that it has something to do with it. although it is running rich with the p14..or maybe i just need to go ahead and throw the p13 in and see what happens
Old Feb 4, 2007 | 08:22 AM
preludefien
Guest
Posts: n/a
Default Re: injector cel (preludefien)
anyone have any suggestions
mondiex
May 28, 2012 09:55 PM
PreLuDeSiR
Apr 26, 2005 10:15 AM
yohan
Sep 27, 2004 08:33 PM
caliriptide
Aug 12, 2003 10:20 AM
Hbgsr
Nov 7, 2002 05:21 AM
