Serious VTEC Problem..
Old Feb 11, 2007 | 06:27 PM
Slow_BB6's Avatar
Default Serious VTEC Problem..
Well lately I have been having a serious VTEC problem, my VTEC engages but as soon as it engages it will just sputter and kind of limp its way up till about 6000 RPM then my car will continue to accelerate prpoperly. My modification list is currently, Apexi N1 cat back w/cat delete, DC header, AEM SRI, Skunk2 IM w/ 68mm throttle body, Exedy Stage 2 clutch w/Fidanza flywheel, P28 running off Hondata S300 and an OBD1 conversion, BDL fuel rail w/ Aeromotive FPR and BDL cam gears.. I have tried everything I even replaced the VTEC solenoid, problems didn't occur until the P28 Hondata and OBD1 conversion so im guessing the problem is somewhere in there, car has had hours of tuning and still cant find the problem.. Anybody have any ideas ?
EDIT: Don't know if this matters but its a 1998 base model.
Old Feb 11, 2007 | 09:37 PM
Flip.'s Avatar
Default Re: Serious VTEC Problem.. (Slow_BB6)
Who was it tuned by, you or a shop?
Old Feb 12, 2007 | 07:29 AM
InvaderTrax's Avatar
Check your oil level
Old Feb 12, 2007 | 07:34 AM
thegeorge613's Avatar
Check your VTEC solenoid.
Old Feb 12, 2007 | 09:21 AM
preludeguy_92's Avatar
Default Re: Serious VTEC Problem.. (thegeorge613)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_BB6 &raquo;</TD></TR><TR><TD CLASS="quote">Well lately I have been having a serious VTEC problem, my VTEC engages but as soon as it engages it will just sputter and kind of limp its way up till about 6000 RPM then my car will continue to accelerate prpoperly. My modification list is currently, Apexi N1 cat back w/cat delete, DC header, AEM SRI, Skunk2 IM w/ 68mm throttle body, Exedy Stage 2 clutch w/Fidanza flywheel, P28 running off Hondata S300 and an OBD1 conversion, BDL fuel rail w/ Aeromotive FPR and BDL cam gears.. I have tried everything I even replaced the VTEC solenoid, problems didn't occur until the P28 Hondata and OBD1 conversion so im guessing the problem is somewhere in there, car has had hours of tuning and still cant find the problem.. Anybody have any ideas ?
EDIT: Don't know if this matters but its a 1998 base model.</TD></TR></TABLE>
Old Feb 12, 2007 | 01:13 PM
prelittlelude's Avatar
sounds like a tuning issue. since you not runing off of a stock honda ecu anymore i would open up the honda software and log everything .. maybe your going way to rich at cross over.. could be alot of things. You problems don't fall in the realm of stock ecu issues.
Old Feb 12, 2007 | 01:15 PM
alterdcreations's Avatar
Default Re: Serious VTEC Problem.. (prelittlelude)
might be the o-ring in the head on the nuber 3 center cam cap
Old Feb 12, 2007 | 05:20 PM
Slow_BB6's Avatar
Default Re: Serious VTEC Problem.. (alterdcreations)
Oil is fine that was the first thing I checked, I replaced the VTEC solenoid like stated above, iit has to be a tuning problem though because if I ease my way into VTEC it goes fine but if I take it to 4k RPM then floor it I have the problem.
Old Feb 12, 2007 | 05:24 PM
I would check your grounds it sounds like maybe when your engine jerks you have a connection coming loose. maybe.
Old Feb 12, 2007 | 05:42 PM
SKDRCR's Avatar
Default Re: Serious VTEC Problem.. (preludeguy_92)
Post up a couple dyno graphs if you can.
Old Feb 14, 2007 | 07:03 AM
Slow_BB6's Avatar
Default Re: Serious VTEC Problem.. (SKDRCR)
Will do, should have her on the dyno as soon as this horrible weather clears.
Old Feb 14, 2007 | 07:06 AM
ice here in N.y.
Old Feb 14, 2007 | 07:16 AM
M3BimmerBilly's Avatar
all those mods and now your car is slower than stock...hahahaha!!!!
brokeHonda
Jul 19, 2009 12:11 PM
ekhatchgirl
Aug 2, 2005 12:21 PM
Simple SOHC
Aug 29, 2004 08:46 PM
Brian-Brian
Jun 16, 2003 04:11 PM
