help
Old Jun 23, 2010 | 01:15 PM
91H22REX's Avatar
Default help
i have a h22a swap and my problem is wen u give it more then half throttle it bogs down and spits and sputters please help wat is causeing this?
Old Jun 23, 2010 | 02:58 PM
Kronn 98SH's Avatar
Default Re: help
It's caused by bad spelling.
Seriously, with the amount of information given, how is anyone suppose to provide an accurate guess?
Old Jun 23, 2010 | 03:50 PM
91H22REX's Avatar
Default Re: help
its a h22a swap obd1 has header full exhaust and stock p13 ecu
Old Jun 23, 2010 | 03:52 PM
91H22REX's Avatar
Default Re: help
theres not realy any other information to give it just bogs down and spits and sputters wen u give it half throttle or more unless u slowly push the gas down and let the rpms build then u can go all out
Old Jun 23, 2010 | 04:12 PM
MrLeWayne's Avatar
Default Re: help
*facepalm*
Old Jun 23, 2010 | 04:50 PM
Kronn 98SH's Avatar
Default Re: help
What's your native language? Your spelling did not improve.
What vehicle do you have?
How many miles are on it?
What header?
What exhaust?
What cat converter?
Who did the swap?
How long as the problem been present?
How long ago did you swap?
I'm trying to help but you're zapping my will to live.
Old Jun 23, 2010 | 05:05 PM
91H22REX's Avatar
Default Re: help
its a 91 honda crx with full obd1 wiring front to back out of a eg civic has hot shot header greddy exhaust and no cat has 45K on motor and car has been doin this since i got it so about a month ive tryed 4 different ecus and they dont change anything ive changed the map and tps and still runs the same and a shop in fort wanye indiana did the swap
Old Jun 23, 2010 | 05:42 PM
91H22REX's Avatar
Default Re: help
it also has a 8lb fidanza flywheel and i was wondering are u suppose to put a resistor box on for the swap
Old Jun 23, 2010 | 06:15 PM
Kronn 98SH's Avatar
Default Re: help
You didn't answer the first or last question.
Old Jun 23, 2010 | 06:41 PM
fastdohc's Avatar
Default Re: help
did u tune the car?
are you injectors right?
got fuel management?
is your engine at the right timing?
do u got a good fuel pump and fuel regulator?
and try looking into the idling unit.
Old Jun 23, 2010 | 08:06 PM
MrLeWayne's Avatar
Default Re: help
Answer the questions dude. Directly and fully, thats the way you'll get the most help.
Quote his post and answer each question.
Simple. Use correct spelling and grammar.
Old Jun 23, 2010 | 08:18 PM
91H22REX's Avatar
Default Re: help
Originally Posted by fastdohc
did u tune the car?
the car has stock ecu no tune
injectors are stock
havent done anything to the fuel system
fuel pump works great as far as i know of and same with regulator
and i swapped out the idling unit
Old Jun 23, 2010 | 08:20 PM
91H22REX's Avatar
Default Re: help
my spelling and grammer has nothing to do with getting help if u cant understand me then just dont help cause its pretty clear wat im saying were not in school so spelling shouldnt matter
Old Jun 23, 2010 | 08:32 PM
Kronn 98SH's Avatar
Default Re: help
No effort from you = no effort from me. Good luck with your problem.
Old Jun 24, 2010 | 01:35 AM
kornkid21792's Avatar
Default Re: help
oooooooooooooooooo snap
Old Jun 26, 2010 | 07:47 PM
91H22REX's Avatar
Default Re: help
found out it was a bad spark plug wire it was broke in half
Old Jun 27, 2010 | 12:00 AM
D_Regan's Avatar
Default Re: help
Yes, that would cause a stutter. LOL. I think the main thing was your grammer. It's hard to read a statement when you don't use proper punctuation.
Old Jun 28, 2010 | 11:43 AM
aldarich's Avatar
Default Re: help
Well before you go blabbin to your mom, make sure you are pregnant and if you're not pregnant why do you have to tell your mom you're sexually active? None of her business really.
01ebpbb6
May 23, 2008 12:43 PM
trrbl1bmx
Jan 17, 2007 02:48 PM
ekdriven
Oct 23, 2006 02:53 PM
redprelude
Oct 28, 2003 06:41 PM
