electrical problem? please help
Old Jun 29, 2010 | 10:42 AM
2toneDA's Avatar
Default electrical problem? please help
so i have a 2000 base model prelude, i was taking out the back seats to make room for a seat belt harness bar, i had to relocate a sub amplifier under the drivers seat, and when doing so the positive got loose and arced with the ground to the amp, (i know i should have disconnected the anl fuse but i forgot) also i don't know the relevance but the shop that connected the system got power from the fuse box under the hood, it was connected to 100A battery connection, my problem now is that when i turn my car on the gauge cluster runs fine but when i turn the a/c on the cluster quits working, the interior lights dim and the radio cuts on and off, also i dont know if this is a coincidence but the car is over heating now, the upper radiator hose gets super hot and the lower hose stays cool, please help!
Old Jun 29, 2010 | 11:13 AM
2toneDA's Avatar
Default Re: electrical problem? please help
somebody helllppppp
Old Jun 29, 2010 | 11:37 AM
1GPlusSH's Avatar
when you say "was connected" to 100A battery, that means it's not hooked up anymore?
i would check to make sure all hot wires going to your sub are insulated properly. that is an odd thing to make the car overheat, though. even with the extra pull from the a/c. i know you're in tx, but i'd go without that a/c as much as possible. sweat now instead of sweating over the money you're going to have to drop to fix something else.
Old Jun 29, 2010 | 11:59 AM
2toneDA's Avatar
i d/c the wire so it would stop any current running to the amp to see if that would fix the problem, Texas summers are brutal bro, the car was running awesome before this little mix up, is the upper hose supposed to be running hotter than the lower?
Old Jun 29, 2010 | 12:21 PM
1GPlusSH's Avatar
yes. that hose is always going to be hotter at operating temp. don't worry about it.
i definitely think you have a short somewhere. trace all your wires(for the sub), twice, and then have someone else check. i'd pull your radio and check your leads there, too.
Old Jun 29, 2010 | 12:44 PM
2toneDA's Avatar
ok so was researching other 5th gen electrical problems and one person said it was their ECM fuse so i changed mine and just to see what would happen i left it out and started my car, correct me if im wrong but a car shouldnt start without the ECU fuse, or should it? i also D/c the radio well i pulled the power from it and the fuse and still having the same problem, i also d/c all the power coming from the sub amp and the mid and high amp, and still having the same problem
Old Jun 29, 2010 | 01:58 PM
2toneDA's Avatar
anyone?
Old Jun 29, 2010 | 02:15 PM
integra15's Avatar
I would check all the fuses. Then ask this in the audio forum, I'm sure some of the installers there deal with this.
Old Jun 29, 2010 | 02:19 PM
2toneDA's Avatar
thanks integra, ill re post in audio
Old Jun 29, 2010 | 04:07 PM
2toneDA's Avatar
would it be plausible that i fried my ecu? someone said that might be a possibility?
Old Jun 29, 2010 | 07:00 PM
2toneDA's Avatar
so i went with the ecu theory, and i borrowed one from a friend of mine and i installed it in the place of mine so i reset the ecu and the car wouldn't turn over so i plugged the one that i thought was fried and what do you know? running like a champ again, does anyone know why this would happen? was there a loose ground on the ecu? thanks for your help
Old Jun 30, 2010 | 06:37 PM
1GPlusSH's Avatar
that is odd. i'm glad you got it worked out. i've had odd problems that somehow got worked out when working on computers. i'll commit your fix to memory
Old Jun 30, 2010 | 06:42 PM
Roarinricepot87's Avatar
that's highly possible.. may have the same problem with my ef..
Old Jul 15, 2010 | 05:52 PM
2toneDA's Avatar
thanks to everyone who helped out, after having my car down for two weeks and searching every wire from all the fuse boxes and relays i finally found the problem, turned out to be a loose ground wire, on the negative connection to the frame of the car was loose, thanks again for the help
Perez_cb7
Jul 23, 2013 10:32 AM
2toneDA
Audio / Security / Video
Jul 15, 2010 06:00 PM
eric.may
Sep 8, 2009 09:56 PM
TA Performance
Mar 26, 2007 06:25 AM
mark2379
Sep 8, 2006 11:46 AM
