H22A PROBLEM
Old Jun 9, 2010 | 08:13 PM
JDMPIG's Avatar
Default H22A PROBLEM
I GOT A JDM H22A ...I WAS DRIVING LATE TO WORK AN HIT A ROCK IN THE ROAD DENTED MY OIL PAN PREETY GOOD AN MY HEADERS REPLACED MY OIL PAN BUT WHEN I TRY TOO HIT VTEC CAR BEGINS TOO SPUTTER REALLY BAD I HEAR VTEC TRYING TO ENGAGE CHECKED MY TIMING RAN OPEN HEADERS ANYBODY GOT AN IDEA WAT IT MIGHT BE?????
Old Jun 10, 2010 | 03:46 AM
minilogoguy18's Avatar
Default Re: H22A PROBLEM
First of all turning caps off will help your vtec work. You could have damaged the pickup on the inside causing low pressure which will keep vtec from working. Make sure there is enough oil in the car and test the oil pressure with a test kit or take it somewhere and have it tested. Oh and the totally obvious, if you have a cel get that taken care of first.
Old Jun 10, 2010 | 12:33 PM
nus_dogg's Avatar
Replaced the oil pan and the pickup if damage.
Old Jun 12, 2010 | 11:20 AM
JDMPIG's Avatar
WHEN I REPLACED THE PAN I TOOK OFF THE PICK UP INSPECTED IT COMPARED IT TOO ANOTHER ONE I HAD FROM ANOTHER MOTOR LOOKED FINE FILLED IT UP WITH FRESH OIL EVEN CLEANED THE VTEC CYLINDER NOTHING I HAD A CEL ON FOR NOT HAVEING A KNOCK SENSOR BUT V TEC WOULD STILL HIT BEFORE THE SAME CEL IS ON ONLY...minilogoguy18 WAT DO U MEAN BY TURNING CAPS OFF??? I HEAR VTEC BUT IT MAKE A WEIRD SOUND ALMOST LIKE A MACHINE GUN CAR LOOSES POWER
Old Jun 12, 2010 | 02:53 PM
Caps lock.
If you are throwing a code for the knock sensor then you WILL NOT have vtec, replace the knock sensor. Have fun since they're kinda in a tight spot and cost around $150.
Old Jun 12, 2010 | 05:28 PM
JDMPIG's Avatar
my h22a didn't come with a knock sensor but i still pined it out from my p13ecu along with my vtec an pressure switch that didnt make a difference before ... i bought one from ebay so i can turn off the cel too pass smog last year about a month later it went out but even so still had vtec so that wouldn't make a difference on an obd1 i would think....
Old Jun 12, 2010 | 05:32 PM
nus_dogg's Avatar
Well, get that CEL checked out and fix the problem. I'm pretty sure once you fix the problem for the CEL, VTEC will work. I know you said it worked before you damage your oil pan, but just get the CEL problem fix. Who knows it'll fix it or not; anything can happen.
Old Jun 13, 2010 | 08:04 AM
OBD1 H22a's have knock sensors, if yours didn't come with one then whoever sold you the motor screwed you out of an expensive sensor.
Old Jul 3, 2010 | 01:27 PM
JDMPIG's Avatar
HA FIXED MY PROB WITH OUT WASTING ANY MONEY ADJUSTED MY TIMING AN VTEC IS PULLING STRONG CHECK ENGINE LIGHT STILL ON THOUGH FOR KNOCK!!!!!THANKS FOR ALL THE IDEAS 0_O
jordan_rael_420
Sep 17, 2008 04:07 PM
951dc5
Mar 27, 2007 11:20 AM
duceducecord
Mar 7, 2006 10:37 AM
da9driver
24
Aug 25, 2005 01:00 PM
sikek
Aug 10, 2004 05:49 PM
