93 check engine light.
Old Jun 18, 2010 | 10:08 AM
marsstar102's Avatar
Default 93 check engine light.
i put a header on my car and after i changed it i drove the car home and then the car wouldn't start after that. it has no spark and i have check up to the ignition coil. I was thinking it is either the ICM of the ECM. any help would be great. and does the check engine light turn off after a few seconds with the key in the on position?
Old Jun 18, 2010 | 10:27 AM
Kronn 98SH's Avatar
Default Re: 93 check engine light.
Seek and ye shall find.
https://honda-tech.com/forums/honda-prelude-4/diy-diagnose-check-engine-lights-4th-gen-prelude-2495089/
Old Jun 18, 2010 | 01:47 PM
that doesn't help i know how to check the dtcs i just want to know if the light should turnn off with the key in the on possition and the car off.
Old Jun 18, 2010 | 02:09 PM
92civlude's Avatar
Im pretty sure it does a "bulb check". The light will turn on a few seconds and then turn off. If there is a problem with the pgm-fi system, the light will turn back on and stay on. Whats the code?
Old Jun 18, 2010 | 08:22 PM
miamijdmcoupe524's Avatar
It will turn off yes, im aiming at the either the external coil or the main relay.
Old Jun 19, 2010 | 04:15 PM
The light doesn't turn off non of the dash board lights turn off, and i found that there is no spark or injector pulse. so i bought a ecu on ebay and im hoping that will fix the problem.
Old Jun 19, 2010 | 09:40 PM
92civlude's Avatar
WOW! Bold move. Usually replacing the ECU is the last step in the troubleshooting process.
White93civiclx
Aug 28, 2014 10:00 PM
6KVtec
Honda S2000
27
May 13, 2013 11:12 AM
jb0705
Acura TL, RL & ZDX
Nov 5, 2006 05:15 PM
jorge99hx
Nov 4, 2005 08:29 PM
jakscivic
May 14, 2005 01:49 PM
