h23 help
Old Aug 20, 2010 | 07:33 PM
fastdohc's Avatar
Default h23 help
i have a closed deck h23. i want to put cp pistons in it. i do know that the block has to be sleeved. but i was told that if i put mahle pistons that it will not shred up the block.
this engine is going to be turboed and i want to get atleast 500 horses out of it. can anybody point me in the right dirrection?
Old Aug 20, 2010 | 09:07 PM
Acidcrakker's Avatar
Default Re: h23 help
H22 and H23 need sleeves if you are going to use pretty much anything else other than Mahle.
You can use the F22 block, its made of a different metal.
Old Aug 21, 2010 | 06:06 AM
fastdohc's Avatar
now are mahle pistons good? will they hold lots of boost?
and how many horses can they hold?
Old Aug 21, 2010 | 08:48 PM
Depends. talk to the person who is doing your build.
Mahle pistons come in different sets. Each set is designed to give you a different compression amount.
Turbo builds need lower comp.
Projectludatic
Oct 7, 2010 10:38 PM
mightymaxgst
Jan 20, 2009 08:31 PM
roycivic92
Jan 28, 2006 09:21 PM
Jdmprelude94
Apr 16, 2005 09:10 AM
noslude93
Mar 14, 2003 05:01 AM
