Throttle Dependent Surging.
Old Aug 29, 2010 | 05:34 PM
brianfe's Avatar
Default Throttle Dependent Surging.
Hi All,
My 00 Prelude is having an odd issue that developed mid road trip.
The issue is not gear or speed dependent, it happens in 3rd, 4th and 5th gear. It happens when I am accelerating and is worse in higher gears. It sounds like a thumping noise coming from the front passenger side. Initially I thought it was a loose piece of plastic underneath the car coming loose.
I have reset the ECU and cleaned the air filter. This has helped the problem slightly but it has not fixed it.
My next steps were to verify that spark plugs were not horrible and to check the MAF/MAP sensor voltages.
Any suggestions or advice would be helpful.
Old Aug 29, 2010 | 06:14 PM
brianfe's Avatar
Default Re: Throttle Dependent Surging.
And yes I have read this. :-)
https://honda-tech.com/forums/honda-prelude-4/end-all-idle-surge-bounce-etc-problems-thread-1979500/
Its not surging at idle, only at speed.
Old Aug 29, 2010 | 08:51 PM
brianfe's Avatar
http://www.preludezone.com/5th-gen-h...elerating.html
This appears to be my issue.
Old Aug 29, 2010 | 09:34 PM
Acidcrakker's Avatar
Motor Mounts?
Old Aug 30, 2010 | 10:34 AM
brianfe's Avatar
I am guessing it is a cv boot.Will know more today.
Old Aug 31, 2010 | 12:39 PM
snobordboy's Avatar
Moderator
Sounds like you have an axle going bad to me, probably ripped the boot and lost grease, and /or got dirt inside.
Niceguy123
Feb 19, 2014 08:21 PM
crazyskiier3989
Feb 19, 2010 06:53 AM
paniaguae640
Sep 2, 2007 12:00 AM
piggydog
Oct 22, 2005 10:43 AM
92jdmhatch
Honda S2000
Aug 17, 2005 11:14 AM
