h23 vtec capability?
Old Aug 26, 2010 | 09:22 PM
fastdohc's Avatar
Default h23 vtec capability?
does a 1996 non vtec prelude come with the wire for vtec?
my friend who owns a nonvtec hatch said it came with the vtec wires build in his car. all he had to do was get a vtec ecu. his car now has vtec.
can anyone tell me whats right here?
Old Aug 27, 2010 | 05:14 AM
minilogoguy18's Avatar
Default Re: h23 vtec capability?
You only have the wire for the spool valve, if you order a motor (this is what I did) trace the wires on the RHD harness back to the plug for the oil pressure switch which is a light blue wire and a black ground and pull the plug to the main harness apart and remove the pin. Take that pin and plug it into the empty slot on your harness where it plugs up to the main on the firewall next to the ABS pump and ground the black wire then just plug it up and you will have converted your engine harness for VTEC. You'll also have to extend the plug for the spool valve, it's near the passenger shock tower and is a green/yellow single wire.
Old Aug 27, 2010 | 05:35 AM
fasthatch95's Avatar
You probly have to add them its eazy. As for your friends civic it was vtec at one time if it already had the vtec harness plugs! it was swapped out at one time> you will notice alot of vtec cars replaced with non vtec engines, its a cheap way to get the car on the road again.
Old Aug 27, 2010 | 09:13 PM
fastdohc's Avatar
is there a diagram or a set of instructions i can get for this?
Old Aug 28, 2010 | 09:49 AM
red92si's Avatar
Your H23 engine does not have VTEC. Prelude's from 1993-1996 came pre-wired for VTEC whether they had a VTEC equipped engine or not. So you can't just throw in a P13 ECU and attach some wires to the current motor and gain VTEC. If you swap in a engine equipped with VTEC (H22A, F20B, etc.) and then swap in the appropriate ECU, then you will have VTEC.
All Honda did was save you the time of running one wire.
Old Aug 28, 2010 | 10:25 AM
92civlude's Avatar
Originally Posted by red92si
Your H23 engine does not have VTEC. Prelude's from 1993-1996 came pre-wired for VTEC swap in the appropriate ECU, then you will have VTEC
So are the vtec solenoid and oil pressure connectors are just hanging there on cars without vtec? Bull. Not all 4th gen ludes are prewired for VTEC.
Old Aug 30, 2010 | 08:51 AM
AznBlueBoy's Avatar
Have you not heard about the h23vtec from factory? It is an OBD2 motor that came from an accord wagon.
Old Aug 30, 2010 | 11:16 PM
kaymoto's Avatar
lol, when I was working at bailey's auto salvage I personally had the unfortunate duty of removing all of the wiring harnesses from the cars before they got crushed.. I have never seen ANY honda's except a few 99-00 civic non vtec's that were wired for vtec. IDK why, but if your going vtec in a non vtec chassis you'll only have your spool valve wire in the harness already. from my experience anyway. but it's not like running a decent hand made sub harness for your vtec is really that difficult lol
Old Aug 31, 2010 | 11:59 AM
red92si's Avatar
Of course, but I highly doubt that is the H23 inside the OP's Prelude.
Old Aug 31, 2010 | 12:02 PM
red92si's Avatar
1993-1996 "Si" models are pre-wired. "S" models are not. And only the blue wire for the solenoid is pre-wired. Still have to run the wire for the oil pressure switch.
Old Aug 31, 2010 | 12:58 PM
92civlude's Avatar
So is the blue wire in the ECU connector already? The VTEC driver terminal 15 at C415. The vtec sol wire is always green/yellow. ALWAYS.
Old Aug 31, 2010 | 01:48 PM
snobordboy's Avatar
Moderator
My 93 Si had the green/ yellow wire, and the light blue wire pre-run. The light blue one was hiding taped up in another harness, but it was there, so I didn't have to change any pins or add any wires on the ECU side of the harness. Just had to wire in the plug to the sensor on that blue wire, and ground it.
Old Aug 31, 2010 | 02:28 PM
92civlude's Avatar
Can anyone confirm this? Ive done 4 H23 to H22 swaps on 4th gens and there werent any f*cken obscure wires in there.
Old Aug 31, 2010 | 02:41 PM
pentaq's Avatar
Neither me. Both in Euro and USDM versions I met.
Old Aug 31, 2010 | 05:31 PM
fastdohc's Avatar
good i got the 96 si prelude.
so the wire is yellow or blue?
meanshyguy
Apr 26, 2009 01:12 PM
allsho
Jun 14, 2007 12:06 PM
projecthonda
Feb 23, 2007 06:48 PM
CIVIC96DXcp
May 7, 2005 09:27 AM
lhd dc2
Aug 20, 2004 03:27 PM
