alternator/battery/sensor problem? need help
Old Aug 28, 2010 | 12:13 PM
9sludei0's Avatar
Default alternator/battery/sensor problem? need help
well i replaced the alternator and the battery and my battery light is still on, i took it to get my car checked at advance and they said there was absolutely no charge going to the battery, however i've been driving my lude for about a day, with a/c on full blast and my system on too, and there is no noticeable loss of power at all, anyone know what it could be?
Old Aug 29, 2010 | 12:02 PM
rjr162's Avatar
Default Re: alternator/battery/sensor problem? need help
You're battery doesn't power the car when it's running, the alternator does. The battery helps smooth ripples and is actually a load (drain) on the alternator. As long as the battery has enough power to start the car and get the engine going, you could disconnect it and the car will still run (FYI> NOT the best idea with cars that have computers). It is possible your battery isn't charging, but you'd find out after a few times of starting and shutting off the motor
Old Aug 29, 2010 | 12:22 PM
Kronn 98SH's Avatar
It sounds like a bad connection between the alternator and the battery.
ALLDAY-24
18
May 3, 2011 08:25 AM
aSDthing
Feb 12, 2008 06:03 PM
idewson
Aug 31, 2006 11:45 AM
IHTFP
Jul 30, 2006 07:01 PM
dog the bounty hunter
Feb 5, 2006 11:50 AM
