Any tips on removing/installing header?
Old Mar 4, 2003 | 09:28 PM
ophdehEEzY
Guest
Posts: n/a
Default Any tips on removing/installing header?
Just wondering if anyone can give me some tips on removing and/or installing a header on a 4th gen h22? TIA!
ophdeheezy
Old Mar 4, 2003 | 09:35 PM
Que_Lude's Avatar
Default Re: Any tips on removing/installing header? (ophdeheezy)
STart taking the bolts off untill there are none left...
Do a search on the net, there are a few sites that have DC Header installs on hondas.
In General:
Jack the front end of your car up
Remove the bolts to the cat
Disconnect 02 sensor
Remove support bolt for B pipe
Remove the bolts from the B pipe to the header
Remove support bolts near bottom of header
Remove 9 header bolts
Can use liquid wrench on the bolts for +1hr or more which will help. Good luck
Old Mar 5, 2003 | 09:02 AM
577HondaPrelude's Avatar
Default Re: Any tips on removing/installing header? (Que_Lude)
Hit ALL the bolts that need to come off with lots of WD40 1 to 2 times a day for about 4 days before you plan on taking the old one off. Also don't drive it druing this time. This will make the bolts come off with ease. Trust me this will save you lots of time. Those bolts tent to really get stuck in a bad way.
JDM_Acccord
Apr 24, 2007 02:00 PM
Zulu888
Jun 16, 2006 05:49 PM
Agent STFU
Jul 24, 2003 11:09 PM
yellowbuffalo
Jan 1, 2003 06:06 PM
jdmspoonitr
Nov 17, 2002 01:32 PM
