Upper control arm?
Old Oct 26, 2011 | 01:28 PM
92_luder's Avatar
Default Upper control arm?
so im lowerd 2.5 in and my upper control arm/upper ball joint n the front hit the inside of the fender....what methods do you guys use to fix...jus a couple suggestions....i wanna go a little lower
Old Oct 26, 2011 | 01:42 PM
Hawkze_2.3's Avatar
Default Re: Upper control arm?
Raise your car to a drive-able height.
Old Oct 27, 2011 | 03:37 PM
wolf95's Avatar
saws-all ^_^
Old Oct 28, 2011 | 01:33 PM
Apex1972's Avatar
i cut out my shock towers. no more scrubbin dawg.
Old Oct 29, 2011 | 12:05 PM
LatnKng's Avatar
...true..i take it you dont really raise the hood at any car events!! May have solved your problem, but you CUT the shock towers instead of alternate solutions, but i guess you can call that an ALTERNATE solution. I DNT LIKE...just my opinion.
Old Oct 29, 2011 | 12:08 PM
Fliptard's Avatar
Cuttting the shock tower greatly reduces strength in that part of the car. Hope it does't break anything later on.
Old Oct 29, 2011 | 05:47 PM
darkestfenix's Avatar
do like the guy did. cut a hole in that area.... but it only has to be 1-2 inch in diameter. not a 6 by 6 inch square.
Old Oct 30, 2011 | 08:16 AM
LatnKng's Avatar
THANK YOU !! I dont think ive seen anyone do that before on their car just to reduce knocking from that area. That should tell you that theres got to be another way or better products out there that can prevent this...i.e..THE CUTTING OF THE TOWERS..IMMENSLY!!
Old Oct 30, 2011 | 10:55 AM
Hidenplanvew's Avatar
actually it was pretty popular to do that with uper control arm camber kits .. also if you cant tell it was cut from the factory and is only sealed with like a liquid glue or something.
Old Oct 30, 2011 | 11:50 AM
LatnKng's Avatar
true..i have noticed on mine as well..but im sure the reason of why they decided to EPOXY-it ( if you will ) back together was for a good reason..from factory im assuming.
Old Oct 31, 2011 | 04:11 PM
preludeNApower's Avatar
Mine have bad clearance, to solve i grinded both the control arm and inside the wheel well to provide better clearance. This has helped but not 100%
Old Oct 31, 2011 | 07:22 PM
I think I would be more scared to grind the upper control arm then cut a hole
Old Nov 2, 2011 | 01:07 PM
92_luder's Avatar
yeah i thought of this jus wanted to make sure it wasnt a COMPLETELY *** idea, i dont think im goin to cut as big a hole tho....n i think ill try to grommet the edge with something to clean that look up a bit
Old Nov 2, 2011 | 01:11 PM
92_luder's Avatar
im not touchin that arm, anybody seen any aftermarket upper arms or anything
Old Nov 2, 2011 | 01:12 PM
92_luder's Avatar
my thoughts too
Old Nov 2, 2011 | 01:14 PM
92_luder's Avatar
this is the first time i seen a wire tucked engine bay, it looks great...off topic, but that isnt the oem abs pump for our car is it?
Old Nov 2, 2011 | 01:15 PM
92_luder's Avatar
noticed this too but it is peculiar that honda would do that....
Old Nov 2, 2011 | 02:36 PM
LatnKng's Avatar
I might do that as well..cutting just doesnt sit well with me. Has anyone one seen or heard of such a thing seriously affecting driveability or anything of that nature after cutting?
jadugartir
Jan 6, 2008 12:16 PM
staticrex
Nov 3, 2005 12:22 PM
thomst4R
Suspension & Brakes
Jul 17, 2005 06:20 PM
extracrunchie
Dec 20, 2004 09:47 AM
illusion
Sep 5, 2002 01:23 PM
