Is this gonna be a problem?
Old Nov 1, 2011 | 06:26 PM
JusAccord's Avatar
Default Is this gonna be a problem?
im missing this connector on the used motor i bought from somebody, is this gonna be a problem? could it be the reason why the motor is not turning all the way? what is it for anyways?
Old Nov 1, 2011 | 06:41 PM
oneprelude's Avatar
Default Re: Is this gonna be a problem?
Its a crank sensor wire, just ignore it if you are dropping the motor into an obd1 car
Old Nov 1, 2011 | 06:42 PM
Doman's Avatar
You can solder the wires or get the plug from the old engine
Old Nov 1, 2011 | 09:03 PM
nus_dogg's Avatar
You can only ignore it if you're running an OBD1 distributor; otherwise, you'll need to solder it and get it plugged in if you're staying OBD2 or engine will not run.
Old Nov 2, 2011 | 03:07 PM
JusAccord's Avatar
damn i think im running a OBD2, how would i know its a OBD2
Old Nov 2, 2011 | 03:24 PM
typemismatch's Avatar
Honda owns me
If that's your car on your avatar and the wiring and ecu are stock, you're OBD2.
96+ Preludes are OBD2 unless they've been converted.
Old Nov 2, 2011 | 03:32 PM
JusAccord's Avatar
actually im sure the car is OBD2 cuz when i pulled the old motor out i remember seeing that crank sensor. ****.. i gotta buy one now
Old Nov 2, 2011 | 03:33 PM
JusAccord's Avatar
yea thats my car on the avatar
Old Nov 2, 2011 | 03:45 PM
oneprelude's Avatar
Then, it's a direct bolt on
Old Nov 2, 2011 | 03:53 PM
JusAccord's Avatar
ok kool, good lookin out!
killerpenguin21
Aug 26, 2008 09:37 AM
Tuan
Feb 17, 2008 07:32 PM
killerpenguin21
May 23, 2007 04:06 PM
strictly.business
Nov 25, 2006 09:05 PM
